Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
930 Efi
Looking for recommendations on EFI conversion for my 930 street motor..Whats user friendly,available,and works.THANX IN ADVANCE
Old 11-02-2007, 06:46 AM
rotorhead's Avatar
I EFI'd my 930 without too much trouble using the kit from www.goingsuperfast.com
I guess you need to decide the reason for EFI, if it is HP then a carerra intake manifold and custom intercooler will be needed. If not then the injector blocks will suffice.
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 11-02-2007, 07:01 AM
what? me worry?
TimT's Avatar
Lots of different paths you can follow. From uber expensive MoTec and EFI systems (mfg) to something like SDS or Megasquirt, a real grassroots home built EFI system.
Do you plan on installing the system yourself? We have installed/converted a bunch of Porsches to EFI 911,930,944, also BMW,Mazda,Nissan,Mercedes..and have worked with most of the systems available.
We really like the Haltech systems. If you want to see some installations or to buy a Haltech system we are located just down the road in Freeport. Give a calll or drop by.
Of course you will get lots of really good advice on this forum as well.
Check out the videos section for some clips of a haltech controlled car with over 800 hp
http://www.rudtnersracing.com/
http://www.rudtnersracing.com/management.php
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 11-02-2007, 09:03 AM
David's Avatar
My standard advice is to find a good shop to work with. I'm as hardcore a DIY'r as they come, but when it came time to tune my engine, I looked at this extremely expensive engine I just built and decided it wasn't worth blowing it up just so I could learn to tune it.
I also spent several hundred dollars I didn't need to spend because I was taking advice from every direction. This was mainly on sensors and pickups that weren't what I really needed.
A little more money spent up front on the ECU can save hundreds in tuning if your tuner already knows the system.
2014 Cayman S
2011 Cayenne Turbo
Old 11-03-2007, 03:58 AM
930gt-40r's Avatar
I did pretty well with Accell DFI. I had to use the kit for the Grand National, but I am pretty sure that they have a 6 cylinder universal kit now. It is a stout system and does not cost a trillion dollars.
My two pennies...
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 11-03-2007, 10:23 AM
930gt-40r's Avatar
Oh yea, the Accel dual sync distributer is the $hit, it takes care of both cam and crank signals via two hall sensors inside the distributer and it is pretty damned accurate. About 400$
Kris @ Tech9
86' 930/GT-40R Sold
Old 11-03-2007, 10:26 AM
935TURBO's Avatar
I'm still.........learning....and did no choice......
Take a look at that thread......
EFI....again...?......
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 11-03-2007, 12:28 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
