Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Porsche Crest 930 engine wiring problems
My 930 engine loom had been seriously hacked about by some clueless idiot prior to me getting the engine and rebuilding it. I plan to make a new engine loom but before I can start this I need to know what a few of the cut wires used to connect to.
I have no JPT plugs on my loom to link up to the warm-up valve and extra air valve (?) What should these connect to and where should i be looking?
I think I have figured out where the remaining wires connect, fingers crossed!
Thanks for the help,
Fergus
Old 11-04-2007, 04:15 AM
I believe they apply 12v to each device....I am not sure if it pulls currant directly from the battery or if it goes through the ECU.. ECU pulling engine temp and adjusting currant to each device as the car warms up. The wiring schematic would show you..
Sorry I just tried to up load some of the electrical schematic..had problems will try later.
1987 930 -Guards Red
2001 740I sport Blk
2011 F-150 supercrew Blk
2014 X3 2.8 white
"What goes around comes around..."
Old 11-04-2007, 07:14 AM
The Mystery pair brown and brown with red stripe go to the oil temp switch that screws into the top of the breather cover just to the left (in your picture) of the red oil pressure switch....
Andy Glass
'86 930 Kokeln IC, K27-7200, SC cams, GHL headers, Fabspeed muffler, Short R&P , misc other mistakes made...
Old 11-04-2007, 08:17 AM
A fellow Pelacanite
NathanUK's Avatar
The WUR & the AAV both get 12V at the same time as the fuel pumps. This is so no matter how long the ignition is left switched on, those two decices know exactly how long the engine has been running (or cranking & running to be precise).
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 11-04-2007, 09:28 AM
A fellow Pelacanite
NathanUK's Avatar
I'm guessing that the yellow wire is the one that runs to its own terminal on the starter motor?
A fellow Pelacanite
NathanUK's Avatar
Is the white wire for the overboost switch?
Old 11-04-2007, 09:30 AM
A fellow Pelacanite
NathanUK's Avatar
There should also be a connector (like the WUR & AAV plug) that goes to the CIS metering flap, this triggers the fuel pumps. I wonder if that is the brown and the brown & red wire.
Old 11-04-2007, 09:32 AM
A fellow Pelacanite
NathanUK's Avatar
There should also be two wires that run to the switch that lives in the LH side timing chain cover. This triggers the cold start injector.
Old 11-04-2007, 09:33 AM
A fellow Pelacanite
NathanUK's Avatar
Hmm, looks like a good excuse to go EFI
Old 11-04-2007, 09:35 AM
930gt-40r's Avatar
Damn bro, It would be easier to $hitcan the harness, buy another from Rob @ DC auto and then do an EFI sys like Nathan says just to treat yourself for the aggrivation.
Or if your near NY or CT, throw me a few bucks and Ill re-wire it.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 11-04-2007, 05:24 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
