Wastgate hose help
Is this the proper connection to the wastegate? The PO had the hose coming from the intercooler. Thanks.
Old 11-04-2007, 04:27 PM
930gt-40r's Avatar
Origonal or not, that will work. The Kokeln intercooler pulls boost reference from the the back end tank.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 11-04-2007, 05:09 PM
resident samsquamch
sand_man's Avatar
Isn't that the connection (coming off that location on the intake manifold) for the vacuum assist brake booster? Not sure about what mods you've got. My wastegate line attaches to the intercooler.
-jeff
Old 11-04-2007, 05:17 PM
Attached to the intercooler with the other side open to atmosphere.
Old 11-04-2007, 05:33 PM
That would be correct. you want the top wastegate port to atmosphere. and the side port to the intercooler
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 11-04-2007, 07:27 PM
930gt-40r's Avatar
That is for the brake booster, wow. I havent looked at the pancake in so long that I forgot. My 3.2 plenum spoils me.
still works for the wastegate even if the brake pedal is a little hard
Kris @ Tech9
86' 930/GT-40R Sold
Old 11-04-2007, 08:35 PM
Forced Induction Junkie
WERK I's Avatar
That hose is for the brake booster line. Not only that, the i.d. of the brake booster line is too large to fit the WG fitting. It more than likely is leaking air around the WG line.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 11-05-2007, 07:03 AM
A fellow Pelacanite
NathanUK's Avatar
Guys, that will not work properly at all.
The wastegate will not open when he closes the throttle
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 11-05-2007, 12:06 PM
why not just run 1/4" vaccum hose to the port on the intercooler?
John A.
Old 11-05-2007, 01:16 PM
930gt-40r's Avatar
Nathan I think your thinking of the re-circ valve- the wastegate dont need to open on closed throttle. Bull-hit aside that port would give him great wastegate actuation, just not good brake actuation. I just plain dont remember where the reference port for the waste gate is on those origonal manifolds/systems- all I remember is that the Kokeln I/C has a port on the back end tank for the W/G.
Also, what ever the biggest diameter hose that will seal to the wastegate connection and reference port is the size you want. In this case larger diameter is better.
Kris @ Tech9
86' 930/GT-40R Sold
Old 11-05-2007, 03:13 PM
A fellow Pelacanite
NathanUK's Avatar
The stock location for the WG control line is on the left hand side of the IC (the inlet side of the IC).
The control line for the recirc valve is connected to the inlet manifold side of the TB.
Old 11-06-2007, 12:28 PM
WERK I's Avatar
Generally, the wastegate control line is off an area above the throttle body. When you have the wastegate line below the throttle body, the wastegate will close when the throttle is closed (i.e. between shifts). It will still work, just not as well as above the throttle body.
Dave
Old 11-06-2007, 04:27 PM
930gt-40r's Avatar
I think Ide want the WG to close as fast as possible between shifts..
But yes, as long as the re-circ, blow off, or what have you is hooked up after the TB and the gate is hooked to a to an un-restricted boost source above or below the throttle body- our motors will be happy campers.
Kris @ Tech9
86' 930/GT-40R Sold
Old 11-06-2007, 07:05 PM
