lin7310948's Avatar
transaxle question????
i currently have a rebuilt 1976 930 transaxle in my street only car. i also have a 76 930 limited slip transaxle needing synchros, etc. on the shelf. would swapping the limited slip out of one into the other be cheaper than a rebuild and if so what is involved with the swap?... also i am in the greenville, sc area and is there a shop nearby for this? thanks for any advice!!
71 911 all alum 434 sbc 585 chp 1959 austin healey bn-6 sbc zz4 motor 200r4 aod transmission......1959 Austin healey bn6 250 chev in line six cylinder, tremec 5 speed
Old 11-05-2007, 04:25 AM
Swapping the diff is best left to a transmission specialist with the appropriate special tools and expertise. My gearbox man says you can swap the LSD with the tranny in the car if you've already taken very accurate measurements of that specific tranny (and the new and old diffs) on the bench, otherwise it really should come out for the work.
If the LSD is a factory ZF, it's really not the best thing to use, JMO.
There's a couple of good recent threads on LSDs in the 911 forum (with posts by Bill V and Paul Guard of Guard Transmissions, aka geary), and many more if you go back a bit further.
The GT LSDs seem to be the best-regarded friction-type LSDs available.
'77 S with '78 930 power and a few other things.
Old 11-05-2007, 12:02 PM
A fellow Pelacanite
NathanUK's Avatar
Yeah, swapping diff's is not really a DIY job. It is mentioned in the workshop manual and can be done but rebuilding syncro's seems much more simple than that to me...
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 11-05-2007, 01:14 PM
