Fuel Pump Fuse Hot to Touch!
Was out driving to the In-laws, 930 dies, check fuses, Fuel Pump burned, replaced with non-used white(8amp?). Checked it out today, talked to a Mechanic, said Fuel pumps draw high amps, replace with higher amp fuse, stuck in a Blue. Still get hot. Is this a common occurance? Fuel pump going? Does not burn fuses, just gets hot. Ideas? Bad Ground too much resistance?
88' 930 03 Tacoma, 04 Duramax, 06 R350 Benz If you are traveling at the speed of light & turn on your headlights, does anything happen? |
Try the Lee Rice electrical conversion. It takes the power from the battery instead of through the existing fuse panel and miles of wire. I used two spade type fuses since I couldn't get the Porsche fuse type holders.
http://www.pelicanparts.com/techarticles/rice_ramblings/rice_ramblings-2.htm http://www.pelicanparts.com/techarticles/rice_ramblings/rice-2.gif |
Got a Picture? So it wasnt just mine!
Could the fuse be a little loose in the fixture? That sounds like somthing arcking
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
Cleaned connections with a Dremel. Seems to be a little cooler, gets hot, just not as hot. Ordered new 3 fuse block, will be using the Tech article to fix. Think I have to read it over a few more times to be clear. Also liked the complete change over to ATO fuses that Fred Cook(?) did.
I like the blade type fuses and I am probley doing the conversion that fred did to all of them, only a little cleaner
When & if you do, can you pass along the parts & sources? I would like to do this as well.
A fellow Pelacanite
The fuses/fusebox is a common problem. Always throw away fuses, clean the box terminals and tighten the tension holding the fuse in place. Check the screw too.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
