OverBoost switch
Should the overboost switch be normally closed? i.e. show continuity to the intake when checked with an ohmmeter? I'm trying to see if I should replace mine.
Yes, normally closed. It's a standard test to bypass the switch by grounding the white wire. It should go open somewhere around 16psi I think.
Andy Glass '86 930 Kokeln IC, K27-7200, SC cams, GHL headers, Fabspeed muffler, Short R&P , misc other mistakes made... |
