Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
newby please help 930 no boost
i have a 79 930 with 70k miles car has not been used much recently had it out and realized there was no boost, i have checked for a stuck wastegate and it seems fine i have replaced intercooler o ring and still no luck i have also checked the intake side of the turbo the shaft has no play and spins free. any ideas thanks
Old 11-10-2007, 05:10 PM
A fellow Pelacanite
NathanUK's Avatar
I wonder if your recirc valve is jammed open.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 11-10-2007, 05:29 PM
at the risk of sounding stupid, where is the recirc valve?
Old 11-10-2007, 06:30 PM
rotorhead's Avatar
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 11-10-2007, 07:26 PM
youngkang's Avatar
That would be under the intercooler.
86' 930 red "Wild @ss Hotrod" Thanks John
Old 11-10-2007, 10:43 PM
930gt-40r's Avatar
Has to be the re-circ valve because the car would spit,sputter, and fart like a champ with an atmospheric boost leak. The re-circ valve creates a boost leak that doesnt violate the fuel metering's calculations. This is assuming it is not the wast gate being stuck open.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 11-11-2007, 10:29 AM
A fellow Pelacanite
NathanUK's Avatar
I would block off the exhaust with a rag while an assistant revs up the engine and I would listen at the wastegate dump pipe for any exhaust letting by.
Old 11-11-2007, 10:58 AM
cycling has-been
bkreigsr's Avatar
when I first got my 77, the valve in the waste-gate was cracked and would not seat fully....very low or no boost.
the seating surface was almost completely gone.
I found out when I took it to be dyno-ed for some baseline numbers.
Bill K
Old 11-12-2007, 10:10 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
