Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
symptoms of a bad injector
Anyone experience having a bad injector? How did your 930 run? Im still trying to solve my problem. Thanks!
79 Euro 930
Old 11-10-2007, 07:13 PM
A fellow Pelacanite
NathanUK's Avatar
Looking at the plugs might give you a clue as to which one may be faulty.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 11-11-2007, 12:40 AM
I"ll give that a try, thanks!
79 Euro 930
Old 11-11-2007, 08:00 AM
Sometimes you can measure the temp of the header pipe with a hand held pyro or even you hand and find the missing cyl.
A 930 with a bad injector will miss kinda badly and be down on power alot.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 11-11-2007, 03:30 PM
That sounds about right!
79 Euro 930
Old 11-11-2007, 09:43 PM
Thanks all that have responded thus far! I began pulling spark plugs and found #5 not tan and clean burning like the rest. It looks to be fouled, like it has been intermitently firing with a light fuel smell. I will replace the injector and clean the plug. Wires and plugs are fairly new. The hesitation off the line and cruising didn't start until after I stopped and got gas during a 400mi drive. I just replaced the filter so I hope this does it.
79 Euro 930
Old 11-13-2007, 02:41 PM
I had a few badly performing injectors on my previous 3.3 turbo (89 model).
I used to feel a hesitation or very slight misfire on light throttle holding at a steady speed or trying to accelerate very gradually,,replaced all 6 off them and hesitation went away!!
Old 11-14-2007, 11:08 AM
Well! I changed #5 injector, no change. Looks like I may end up replacing all of them. Is their a pick-up coil in the distributer that can be replaced? Its been a pain trying to solve this problem! Im not sure now if its spark related or not. Im open to suggestions. Thanks again!
79 Euro 930
Old 11-14-2007, 08:19 PM
A fellow Pelacanite
NathanUK's Avatar
There is a coil and it can be tested. I am not sure if you can buy the part separately though.
Old 11-16-2007, 10:23 AM
mark '87 930's Avatar
How are your plug wires? Are they old?
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 11-16-2007, 10:27 AM
Send a message via AIM to Ag02M5
What is they typical lifespan of plug wires? Time and/or miles?
RT
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine.
Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
Old 11-16-2007, 10:31 AM
20K miles is what I've heard.
1956 Chevy 3100
Old 11-16-2007, 10:33 AM
Speaking of bad/old injectors...
I have a 91 with 3x,xxx miles. Seems to be running well but I want to make sure the injectors are up to par.
Would you guys just replace them with new for about $300 or have them individually cleaned and tested?
Or buy a second set of used injectors, and have both sets cleaned and tested. Then pick the best matched set.
RT
Old 11-16-2007, 10:43 AM
Me like track days
Craig 930 RS's Avatar
Easy answer:
Send them to witchhunter. He tests, cleans, sends you the flow and pattern report and you make the easy call upon return - http://www.witchhunter.com/
Local guy 5 miles from me, great service and a perfectionist,
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-16-2007, 11:27 AM
The plug wires have been ohm tested and show to be good. Im going to pull the rest of the injectors since they are almost 29yrs old. (STUP), what you described is exactly the symptoms im having, at times it will clear up and then start hesitating again. Its as if the injector pintle is sticking. I dont have a service manual so can someone tell me what is the best way to get to the injectors and plugs on the left side? Again, thanks!
79 Euro 930
Old 11-16-2007, 03:06 PM
you will need to use 2 spanners for the job in there as they sometimes have to be cracked because they will be tight,,one spanner making sure the injector dosent move when your trying to slacken the nut,i had problems aswell with a set only a month ago on a mates 930..make sure you have good size fitting spanners and if i remember on his i had to cut one down in size!
Old 11-18-2007, 02:26 AM
Thank Stup
79 Euro 930
Old 11-18-2007, 07:30 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
