Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
jt1 jt1 is offline
Which type rear wheel bearings on a 83 ROW 930?
I've done a lot of searching, but am not clear on what type rear wheel bearings are used on my 83 ROW 930. It looks like I may have to remove the hub to replace a damaged 100mm stud. Searches indicate that 67mm studs can be replaces without removing the hub, but 100's require removing the hub. Also indicated is that removing the hub ruins the ball bearing type, but the tapered roller type is not damaged. So, which type do I have? And do I have to remove the hub to replace the stud?
VIR in two weeks......
John
Old 11-16-2007, 04:09 PM
David's Avatar
I don't know if you can, but I'd try real hard to replace it without pulling the hub, it's a real b!tch of a job. I replaced mine with the arms off, I can't imagine doing it with them attached. I think a few folks have, maybe some searching will turn up a link.
2014 Cayman S
2011 Cayenne Turbo
Old 11-17-2007, 05:09 AM
sudo apt-get purge 930
equality72521's Avatar
I replaced then with the arms on and I'll never try it again. I will pull the arms next time.
--clutch-monkey
Old 11-17-2007, 05:14 AM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
I concur,,, if you have to replace the wheel bearing , pull the arms,,
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-17-2007, 05:44 AM
beepbeep's Avatar
You have two conical bearings, not single roller one like on SC.
Thank you for your time,
Old 11-17-2007, 07:17 AM
jt1 jt1 is offline
BeepBeep is correct. My car has the tapered roller bearing setup. Disassembly went smoothly, plug brake line, remove caliper, remove rotor, remove cotter pin and nut. The nut came off with a 1/2" air wrench, then the hub popped off with two pry bars, as per John Walker, but it took a pretty good pull on the bars. The bearing was in good shape, so I replaced the stud, added some grease, and reassembled the whole show. I reused the grease seal, although I would have liked a new one better. I will get the chance to put in a new one pretty soon, probably after the VIR event. While I was under the car, I spotted a very small crease beginning in one of my CV boots. It's not leaking any grease yet, but it's obvious the boot's days are numbered, and I don't want to ruin any of the joints thru stupidity.
Thanks for the help!
John
Old 11-19-2007, 03:20 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
