Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
sudo apt-get purge 930
equality72521's Avatar
First Porsche engine pull
I've pulled other engines, mainly VW air cooled ones but this is my first Porsche engine pull. Took me 4 1/2 hours to do it by myself. Now I'll spend the whole winter fixing all the stuff and cleaning it up. And the mandatory pic:
--clutch-monkey
Old 11-17-2007, 01:48 PM
Congratulations! I just finished that task on mine. Now your only hard task is deciding when "enough is enough" ;-)
Andy Glass
'86 930 Kokeln IC, K27-7200, SC cams, GHL headers, Fabspeed muffler, Short R&P , misc other mistakes made...
Old 11-17-2007, 03:29 PM
Well, I've got it down to the case. Looked at the turbo and as I suspected, it's bad. You can see the side to side movement, maybe 1/16". The backside of the intake valves look pretty good, better than I expected, hardly any deposits. I found the source of all of my leaks, the typical locations. I also found several vacuum leaks, injector blocks were loose, a couple were finger tight. Loose hoses, too.
--clutch-monkey
Old 11-18-2007, 01:53 PM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
youll be suprised how easy the thing goes back in.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 11-18-2007, 03:51 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
