Can euro fuel head handle HFS?
I bought a ported fuel head from a fellow pelican awhile back, and I have just figured out its not getting fuel to the right bank.
I am pulling the dizzy as we speak and was wondering if anyone has run a K27 HFS on a stock euro fuel distributor? It would be easier to just put on my old stock euro dizzy for the time being while I get the ported head cleaned out/repaired, but I want to make sure the turbo can handle it first.
Thanks guys!
P.S. for those of you that have been following this engine start, i do finally have spark! it was that damn green wire.
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 11-21-2007, 09:52 AM
A fellow Pelacanite
NathanUK's Avatar
Depending on what other mods you have it should be fine.
The only real way to know is to use a wideband AFR setup. I have the Innovate XD-16 kit.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 11-21-2007, 01:27 PM
I do have the innovate hand held unit, which I will be using to check AFR's after breaking in the engine. Right now I am just trying to figure out which option will get me on the road the soonest, without causing harm to the engine.
John A.
Old 11-21-2007, 03:46 PM
Me like track days
Craig 930 RS's Avatar
The adjustable WUR is typically done before the fuel head - indeed you may not need the fuel head as will be proven out by your forthcoming AFR test.
You sure and heck will need the adjustable WUR after the massive fuel dump the fuel head provides....at the wrong moments ie from the onset of boost until 4,200 or so. For me it was at 5,200!
Bank on it.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-21-2007, 04:04 PM
Crotchety Old Bastard
RarlyL8's Avatar
The work that my CIS buddy did with setups included the HFS and fuel head mod.
What was found was that the K27S worked best with the Euro head and the HFS worked best with the modded head on that particular engine. The power level cutoff for the fuel head mod was 375whp (< 375 S, >375 HFS) and was independant of the choice of turbo.
Old 11-21-2007, 06:26 PM
I am going to throw the stock one back on for now just b/c I know it is functioning correctly. I wont risk going to redline, but I will just really need it to break in the engine. That should give me enough time to get the modded head tested, and get the adjustable WUR set up
John A.
Old 11-22-2007, 11:15 AM
Me like track days
Back to the original post for a sec:
Who originally did your 'ported fuel head'?
There are older mo(shimmed) fuel head mods out there that will not support the setups we speak of here -
Old 11-22-2007, 04:46 PM
I bought it from a guy that lives in my area. He had it done in FL and sold it to me when he went efi. I dont recall the company that did the mod, but now I am thinking I might just send it to iA and have a trustworthy pro look over it to see what was done, and if it was done correctly. I re-installed my stock euro this evening, and will see if I can get her cranked tomorrow.
John A.
Old 11-22-2007, 06:30 PM
Me like track days
I think you are now on the right track -
Old 11-23-2007, 02:07 PM
