Originally Posted by sand_man View Post
Worst case scenario, we were thinking that the cams could be timed 180 degrees out. As a check, if John got the number one cylinder in place for a valve adjustment at Z1 (number one intake and exhaust valves should be "loose"), then the number four cylinder exhaust and intake valves on the opposite side should be tight (on the passenger side)...right? If number four is "loose" at the same time number one is, would that indicate incorrect cam timing?
Damnit, is this true? If it is, then that theory in the back of my mind was correct and the cam is 180 out. At Z1 the rockers on cylinder 4 are loose, and not compressed. I may have to add this to the "stupidest thing you have done to your Porsche" forum.
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 11-25-2007, 09:23 AM
resident samsquamch
sand_man's Avatar
As I said, set to Z1 as though were going to adjust number 1 cylinder valves ...in which the valves should be "loose", then go over to the passenger side bank and verify that number four is tight...not loose.
I'm pretty sure that's one way to check. Maybe another member can verify...
-jeff
Old 11-25-2007, 09:54 AM
resident samsquamch
sand_man's Avatar
I don't think just arbitrarily setting the engine to Z1 is good enough. You have to determine which cylinder's valves would actually be in a postion to adjust...thus you'll need to remove the valve coveres from both sides of the engine.
-jeff
Old 11-25-2007, 09:58 AM
one of the great unwashed
patkeefe's Avatar
When #1 fires, it as at the nominal top of the stroke, between Compression and Power. Ay this instant, #4 should be at the top between Exhaust and Intake, Unless you have zero overlap in the cams, or your valve lash is set incorrectly, you shouldn't have the valve lash you describe.
Try taking the valve covers off, and watching the valve motions on #1 and #4 for a few rotations of the crank, to see what's what. Just follow along with the I-C-P-E routine a bit, and it will become apparent if you timed the cams wrong.
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 11-25-2007, 10:37 AM
Pop a link to this thread on the rebuilding forum. Those guys do cam timing in their sleep, so you'll have an answer by morning.
Old 11-25-2007, 05:42 PM
