ManaMan's Avatar
Throttle linkage question
Luckily, I wasn't to far from home when this happened. I was driving my '77 930 and pushed on the accelerator pedal, when I felt it give and it went straight to the floorboard. The engine was still running and returned to idle speed.
I pulled over and looked into the engine bay and the throttle linkage looked normal and was still attached. I did notice a slight binding of the accelerator pedal the last couple of times out, but the pressure was only felt from idle to 1,000 rpm...after that it felt normal.
Could the throttle linkage have let go somehow? Is there a cable end that could have broken off? Thanks for any help or suggestions.
Wallace
'77 930 euro project
Old 11-22-2007, 01:30 PM
A fellow Pelacanite
NathanUK's Avatar
Check under the car at the transmission. If no movement then follow it back to the front of the car.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 11-22-2007, 03:15 PM
There are a few different connection points for the throttle. from the throttle to the linkage plate on top of the engine, from linkage plate to drivers side of the transmission, from trans to pedal cluster, from pedal cluster to pedal. either section could pop off, or break.
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 11-22-2007, 03:42 PM
ManaMan's Avatar
Thanks guys, I'll lift the car and check those areas.
Old 11-22-2007, 05:38 PM
