View Poll Results: What are the Best 3.3 Turbo Headers
GHL 9 23.68%
B&B 18 47.37%
GSF 5 13.16%
OBX/OTHER 6 15.79%
Voters: 38. You may not vote on this poll
Metal Guru
911nut's Avatar
Vote for the Best Headers
Of all 930/965 3.3 liter header manufacturers, who provides the best price, performance and durability and manufacturing quality? Please explain your choice.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 11-22-2007, 03:54 PM
Crotchety Old Bastard
RarlyL8's Avatar
Er, I don't see SSI on that list and they sure as hell don't belong in the "other" catagory with OBX. Ha!
Old 11-22-2007, 07:49 PM
Metal Guru
911nut's Avatar
I'm referring to headers that are turbo forward.
As of right now SSi's are heat exchangers only.
Paul B.
'91 964 Turbo
Old 11-23-2007, 04:40 AM
E-85 sippin drunk
turbobrat930's Avatar
I would also put in a box for custom headers from guys such as Marco Manzie, Holcombe, etc....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 11-23-2007, 04:52 AM
RarlyL8's Avatar
What do you mean "turbo forward"?
SSI manufactures heat exchangers for 930s. If you are strictly specifying headers then SSIs do not qualify as they have the pipes enclosed in heat exchangers.
It's no longer a matter of getting what you pay for either. Some of the big players have quality issues. Economy units like OBX are a fitment gamble but cheap enough to hack up and fix if you can weld. All are susceptible to cracking if the exhaust temps are out of wack or when used on track cars.
Old 11-23-2007, 08:40 AM
Metal Guru
911nut's Avatar
From the exhaust ports to the turbo, as opposed to turbo back.
So does SSI make a complete system running to the turbo?
Paul B.
'91 964 Turbo
Old 11-23-2007, 04:51 PM
RarlyL8's Avatar
Ben and I are producing these systems as a bolt-on.
Old 11-23-2007, 05:49 PM
Metal Guru
911nut's Avatar
So far B&B is leading by a wide margin.
Over on Rennlist I read about cracking tubes on B&B and no customer service/warranty.
Comments please.
Brian, is your system for SSI's fabricated from 321 S.S.?
Paul B.
'91 964 Turbo
Old 11-24-2007, 09:11 AM
Wo ist die Rennstrecke?
DonE's Avatar
On the other hand, I wouldn't exactly call them performance headers either.
Old 11-24-2007, 12:42 PM
RarlyL8's Avatar
930 heat exchangers are made from 347 stainless, specifically for the turbo application.
I guess "performance" is subjective. Are they a performance enhancement for a 935? No. For a street 930? Yes.
Old 11-24-2007, 01:23 PM
A fellow Pelacanite
NathanUK's Avatar
I'm pretty happy with my GHL's. They were an excellent fit, look very neat and well made.
The negatives are that the collectors on the B&B's perform better & the GHL's are not 100% stainless steel as the flanges are mild steel/lcs.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
I too have read about cracking on B&B units, most frequently at the collector. My vote goes to GHL because of their noted customer service: you get cracks they will fix or replace them. I also like the turbo-modified SSI headers, it really helps starting with a well proven & high quality product.
Remember, OEM turbo exhaust is the ultimate in strength (and weight), while aftermarket SS headers under boosted pressure and heat will wear out quicker. Look for products with verified 321 stainless.
96 BMW M3 Coupe
89 951
Peugeot moped
Old 11-24-2007, 02:11 PM
This all depends on what you want and what you can do by your own.
I have 2 sets OBX here, on one set I am building heat exchangers around,
the other I leave as they are.
Both sets needed some rebending and checking for
welding/grinding waste inside.
NEVER install OBX without deeply checking them inside!!
We found small loose pieces in both header sets.
Those would have killed the turbo for sure.
Rebended, checked and cleaned they seeme quiet price worth.
...if you are able to do that work and have the equipment!
Cant say anything about the other brands.
Most I like some of the custom headers
which came up here.
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 11-24-2007, 03:38 PM
DonE's Avatar
No, performance is not subjective - it's objective, and quantitative. It either improves throttle response, HP, torque, etc, or it doesn't. Then there is the issue of cost vs it's competition.
I have no experience with SSI, so that's the reason for my original comment.
Old 11-25-2007, 06:10 AM
Wer bremst verliert
JohnJL's Avatar
Maybe not subjective but relative i think is correct. I think the connotation might be lost in translation. You both are right i think.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-26-2007, 02:13 AM
RarlyL8's Avatar
SSI has no competition. There is no other manufacturer on the market that uses 347 or has anything near the quality for the price. If you find anything that comes close post it.
As for performance, to compare the SSI design to the stock US or Euro heat exchangers is an obvious upgrade. All other popular aftermarket headers and heat exchangers use the shortest non-equal length path to the turbo. Good for spool but lacking the low end off-boost tuning of true equal length primaries. Typically only high-end exensive racing headers use this quality of material and design.
Is that a littler better?
Old 11-26-2007, 04:06 AM
Brian the ssi's are 321 and the y joint is 347 jus for all to be clear on
Ben
Current project 73 914-6 Gt project rusteration 2.4
914-6werkshop.com ,heat exchangers, oil tanks, etc
Old 11-26-2007, 04:56 AM
Oh and m&k being a manufacturer dealing with 321 exclusivly I can tell you the ssi set up is fantastic. Ssi make the heat exchanger shorter then the standard ssi using 321 material and a nice V-band. Then rarlyl8 designed the cross over Y and ssi casts the y joint out of 347. M&K then welds the assembly up and you have a very nice,high quality 930 part infact click on my thread in my sig to see them installed on my car. love em other wise would have never gone down that road
Ben
Old 11-26-2007, 05:00 AM
resident samsquamch
sand_man's Avatar
[FLAME SUIT ACTIVATED] such a shame to see those big poll numbers for B&B. My story? I had a well tuned engine (correct timing and AFRs that were checked often) and they cracked at the primary pipe heater box junction. Once removed, I could see the beginnings of several other cracks/holes in the other pipes. They didn't last 8,000 miles.
Mine had been cracked for several months, and I never really noticed it until I installed a muffler and could hear what was going on (had been running a zork). Even then, the leak wasn't obvious as it was occurring within the heater box. That's safe! At any rate, I was about two months beyond (not even) their stated warranty and was on the receiving end of some of the worst customer service relations, imaginable!
So I rolled the dice on the OBX Racing (no heat) with a claimed 321 material and "life time warranty" (yeah right, I'm not that big of a fool). I had no fitment issues on the install. And for what it would cost me to buy another set of B&Bs, I could buy four or five sets of OBX! Maybe I was lucky, and sure on my way home tonight, the OBX could just as easily crack, but I'm satisfied. Mostly satisfied because if they do crack, I won't feel rapped at having plunked down $2,200 for the leak!
These engines are hard on headers. As much as I'd like to own another set of big balla hi dolla headers, I have to be content until I know for sure someone has created a set that aren't "disposable" and will stand behind them even if there are problems. Seems that RarlyL8 and M&K are onto something and maybe by the time my OBX have taken a dump and I've confirmed that my "life time warranty" wasn't worth the paper wasted to print it, I'll be ready for a set...
-jeff
Old 11-26-2007, 06:17 AM
Smart quod bastardus
fredmeister's Avatar
Why are these cars so hard on headers?
I mean is there a way of quantifying how long they shold be expected to last on a car barring any faults from initial manufacturing like crappy welds and such?
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 11-26-2007, 06:44 AM
