beepbeep's Avatar
The icepick
Hello!
A gentleman on another forum uploaded picture of his JE piston that has been living in 924 Turbo with slightly bad fuel injector. I tought it would be a nice picture to share, as many people ask how knock influence pistons.
This is a JE piston and it survived the treatment quite well (no edge erosion, yet) but the hacks are interesting to see. It's like someone took a icepick and wen't loose on it...
Thank you for your time,
Old 11-25-2007, 04:47 AM
Forced Induction Junkie
WERK I's Avatar
Thanks Goran.
Looks like the piston is suffering from frost bite!
Interesting detonation effect. Did the spark plug electrode(s) suffer damage? It almost looks like there was a small object floating in the combustion chamber.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 11-25-2007, 05:22 AM
Wo ist die Rennstrecke?
DonE's Avatar
Good pic - thanks.
This was caused by a bad (lean?) injector? The rest of the engine specs would be interesting, if you have them (timing, CR, etc).
Old 11-25-2007, 06:34 AM
onboost's Avatar
Alrighty now.. since we're on the topic, guess I'll share some pics from a spare motor I purchased off a frustrated individual a couple years back.
Seems this guy thought he was up shifting and insted was down shifting at speed. I bought the grenaded motor for what was salvageable from it, and was able to scrounge some other pieces to use for my EFI build down the road.
Anyway these are photos of up shifting gone bad!
RGruppe #180
Old 11-25-2007, 08:04 AM
beepbeep's Avatar
Originally Posted by WERK-I View Post
Thanks Goran.
No, picks are all done by knocking...interesting enough.
As far as I know, engine is stock 931 engine borde to 87mm and fitted with custom JE pistons. CR is unknown to me but only one cylinder suffered.
Old 11-25-2007, 11:58 PM
BoxxerSix's Avatar
I can say I have NEVER seen that happen from detonation or even pre-ignition. That to me looks like foreign object impact.....scratches in the dome of a piston from detonation????
That piston looks exactly like the JE pistons that were in a mazda miata motor
that ingested a speed loaders worth of toy bb gun ammo apon startup (speedloader fell into aircleaner and was not noticed). Search the mazda forums and you'll find that old post......
That to me looks like the piston dome was "shot peened" with nails............
Adam Hennessy
Old 11-26-2007, 10:55 AM
I tend to side with Adam, though further investigation is needed. The depth and total coverage of the marks look like something rattling around in the chamber. Not much carbon crust either. I wonder how the valves and cylinder dome looked?
96 BMW M3 Coupe
89 951
Peugeot moped
Old 11-26-2007, 11:16 AM
BoxxerSix's Avatar
Exactly. The bad injector causing the lean condition may have lead to part of the piston breaking off and causing that damage, but no way did the actual detonation shock wave do that. Preignition results in holes melted into the dome and ringland transitions. Detonation results in chunks/cracks/particles that can do the damaged pictured above....either that or some part of a(burnt) valve or plug electrode/ceramic, or foreign object ingestion.
Adam Hennessy
Old 11-26-2007, 11:26 AM
Me like track days
Craig 930 RS's Avatar
Looks to me like a bit of ring or valve -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-27-2007, 01:23 PM
boxermania's Avatar
beepbeep
I have seen that type damage before in both Porsches and other makes. The impingement on the top of the piston is not caused by detonation....it might have been precipitated by detonation....but that damage is caused by something that came loose, I would guess a piece of spark plug porcelain that just bounced of f the piston and the head until it finally broke appart.
Or, something came through the intake manifold and got past the intake valve.....is the head off the engine? What does it look like? If it looks the same, I rest my case.
Al Morales
77 911 S (930 steel conversion)
88 BMW M3
79 Honda CBX
Old 11-28-2007, 12:11 PM
beepbeep's Avatar
Just asked the owner what happened. He said that the piston knocked horribly and that damage was probably made by piece of piston itself that dislodged and bounced around in combustion chamber. He found molten aluminium in the headers and turbo as well...
Old 11-28-2007, 12:18 PM
DonE's Avatar
I have custom JE pistons and they don't look like that one. The pictured piston seems to have only 2 rings (top ring and oil ring), has a massive piston skirt (almost looks like a small diesel piston) and no cut-outs for valves.
Interesting.
Old 11-28-2007, 04:42 PM
