sudo apt-get purge 930
equality72521's Avatar
What is this?
I always thought it was an oil pump because of the oil lines to it but there is what appears to be a belt drive pulley inside it. What is this and how does it work? TIA
--clutch-monkey
Old 11-25-2007, 06:43 AM
Turboo934's Avatar
Turbo sump pump,also drive for air pump.
Old 11-25-2007, 07:28 AM
Originally Posted by Turboo934 View Post
Turbo sump pump
So what is the (apparently) belt drive pulley for?
--clutch-monkey
Old 11-25-2007, 07:29 AM
tHE AIR PUMP FOR THE AIR INJECTION.
Old 11-25-2007, 07:40 AM
Turboo934's Avatar
Air pump for air injection.
Old 11-25-2007, 07:42 AM
Ok, so obviously the air pump is disconnected (never seen a pic of the air pump system). Does this piece (pulley) stay in? Is it part of the oil pump? Does anyone have a pic of the full system? I've got the engine pulled for a clean-up, seal and gasket replacement, and whatever else. If it can go it will. Thanks
--clutch-monkey
Old 11-25-2007, 07:44 AM
It needs to stay. the pulley is what is attached to the back of your cam, and drives the pump. The pump pulls oil out of your Turbo drip tank and sends it to the oil tank. Many believe it is a good idea to put an oil filter system between the pump and oil tank, b/c "coked" oil comes from the turbo and is not filtered. The end result being clogged cam tower oil passages.
I have never actually seen an air injection system on a car, mine was pulled way before I got my hands on it.
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 11-25-2007, 09:59 AM
Thanks for the help.
--clutch-monkey
Old 11-25-2007, 04:01 PM
A fellow Pelacanite
NathanUK's Avatar
The air pump sat above the pulley and was driven buy a toothed flat belt. Mine will not be refitted... As stated the pulley has to stay.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 11-26-2007, 11:47 AM
Rory Mckenna's Avatar
Mark,
You doing some Winter time tune up stuff?
Old 11-26-2007, 12:00 PM
Originally Posted by Rory Mckenna View Post
Mark,
Yep, got the engine pulled to fix all the oil leaks I showed you. I'll naturally have to do some painting while I'm in there to make it pretty. Also, my turbo is shot, about 1/16" play in the shaft so I'll be getting a K27 and possibly headers depending on how bad my exhaust system is. Will also put a Tial in but I'll have to stick with the stock intercooler for now. You know, money! Third gear is grinding on the tranny too if I'm not careful with the shift.
--clutch-monkey
Old 11-26-2007, 12:47 PM
It's all worth it though bro.. it's all worth it!
Old 11-26-2007, 12:55 PM
Send a message via AIM to Ag02M5
So can the air pump and the belt going to the air pump go? I'm confused.
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine.
Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
Old 11-27-2007, 10:05 AM
onboost's Avatar
Correct.. "the air pump and the belt going to the air pump" can go! The pulley, connected to the oil pump "as pictured" must stay.
Back in the 90s, someone was offering a billet oil pump that was all the rage as a replacement pump for the original 930 piece "as pictured". It bolted right up and eliminated the pulley and was supposedly a Little lighter for all you diet concious types.
Can't really remember who was selling them though I sure I have it in some notes somewhere. Hmmmm, Windward Performance maybe?
RGruppe #180
Old 11-27-2007, 10:58 AM
A fellow Pelacanite
NathanUK's Avatar
Yep, belt & pump can go.
Old 11-27-2007, 12:46 PM
Already gone. Just wanted to make sure I didn't fark something up.
Old 11-27-2007, 12:47 PM
