wmunchovie's Avatar
danger in overboosting!
Oh what fun it is to take a perfectly good Porsche 3.3 engine, install an in-cab boost knob, turn it way too far and have detonation… rule of thumb; less is more.
munchovie.
Old 11-28-2007, 09:15 PM
Yikes!
Old 11-28-2007, 09:16 PM
wmunchovie's Avatar
here is a closeup - it's a shame because the engine looked so nice on the outside
Old 11-28-2007, 09:25 PM
Rory Mckenna's Avatar
That's why I stay at 0,8... that picture scares the hell out of me. I think the 930 is a pretty fast car at stock boost.
I am sorry that happened toyou.. I am sure you'll build it faster, stronger and lighter than it was before the grenade went off.
Old 11-28-2007, 10:34 PM
935TURBO's Avatar
Really sorry for you wmunchovie.....it's a pity...so much damage.....how much pressure did you have...?.....I heard about racing engine runing with 1.85 Bar and no damage...?...so...?...what's going on...?
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 11-29-2007, 12:32 AM
Crotchety Old Bastard
RarlyL8's Avatar
What boost level caused the damage? What are the specs on that engine?
Old 11-29-2007, 06:38 AM
Forced Induction Junkie
WERK I's Avatar
It appears there are/were higher compression pistons in the engine. 7.5 or 8.0 : 1?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 11-29-2007, 07:27 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
bummer
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-29-2007, 08:43 AM
looks like your broke the ringland (hole in the piston) on the what could have been the leanest cylinder . the temperatures in that cylinder must have been staggering.
but you threw the rod as well , a forged rod for that matter, you must have overrevved or something else . that is alot of damage for just overboosting . the head studs should have snapped way before that would have happened.
it looks like the whole engine is scrap now ...
btw. newb to this forum here ...
Old 11-29-2007, 11:53 AM
Wo ist die Rennstrecke?
DonE's Avatar
I feel your pain - don't ask how, or I'll send you my pics.....
Old 11-29-2007, 06:03 PM
Me like track days
Craig 930 RS's Avatar
Last known statment prior to destruction:
"Hey doods, look my boost is ad-just-able........let's crank it up!"
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-29-2007, 07:06 PM
wmunchovie's Avatar
Well, I’m happy to let you guys know that I bought the car after the damage was done; I just never got around to taking the engine apart. After further inspection it seems as though the 930 was a 3.4 - Ross pistons 8.0:1 101.5mm and had nitrous rings – so I suspect now that not only over-boosted but the big nitrous switch was stuck on… This could account for destroyed rod, it seems.
Anyway, the crank on no. two is pretty bunged up; boat anchor or have the crank repaired? It seems that three of the six cylinders are ok, but I’m just a little shy about using anything from the bottom-end.
The heads looks pretty good; I’m going to disassemble them this weekend, clean them up and check the valves, etc. They are twin plug heads with 38mm intakes.
Munchovie.
Old 11-29-2007, 07:08 PM
930gt-40r's Avatar
The nitrous is where the rod blew up (Nos backfire?) and way too much timing. Unless the boost went way to high. Ive run my car for short sprints at 25 Psi and no problems.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 11-29-2007, 08:31 PM
Metal Guru
911nut's Avatar
I was told by an engine expert where I work that the magic number to a failure of the rod-snapping sort is 10,000 psi in the cylinder.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 11-30-2007, 07:39 AM
