Question Anyone try 205/50 16 tyres on their 930?
I am thinking about putting 205/50 16 tyres on the front wheels of my 930 so I get a lower profile.
The standard size is 205/55 16 so a 50 profile should make quite a difference.
Has anybody done this?
Does anybody have any advice for me?
Please note this is a standard road car.
Many thanks
Old 12-02-2007, 05:36 AM
David's Avatar
The lower profile may help in initial turn in and initial brake application, but besides that it will have less footprint than the 55 series tire since it's shorter. So you'll probably have more understeer and less overall front end grip.
2014 Cayman S
2011 Cayenne Turbo
Old 12-02-2007, 07:26 AM
Turbo Hooligan
go for a 225/50-16 in the front and stick some 245/45-16's on the back. a little lower and a little fatter all the way around.
Old 12-02-2007, 12:23 PM
Thanks for the advice I have 245/45 - 16's on the rear.
Regarding 225/50 - 16's will these have a lower profile than the standard 205/55's?
Ta
Old 12-09-2007, 11:07 AM
David's Avatar
225/50 and 205/55 are the same diameter.
2014 Cayman S
2011 Cayenne Turbo
Old 12-09-2007, 12:00 PM
Macht Schnell
les_garten's Avatar
Hi,
I have 7" and 8" stock Fuchs on my 85 930. What sizes over stock there would most go with?
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 12-09-2007, 12:51 PM
David's Avatar
225/50 and 245/45, although 245/45 are getting hard to come by. You could also go with 245/50, it's just a bit taller.
2014 Cayman S
2011 Cayenne Turbo
Old 12-09-2007, 02:52 PM
Turbo Hooligan
whos making the 245/50's?
Old 12-10-2007, 02:02 PM
