930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Question clutch slippage issue
is it possible that the wrong clutch helper spring(on the trans) would give me slippage problems? I purchased the spring on e-bay and probably got whacked . the guy said it was for a 930 but im begining to wonder.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-07-2007, 07:03 AM
930turbo's Avatar
The helper spring should have no influence on clamping force. If properly installed, the helper spring (omega spring) does nothing when the clutch is engaged due to its on-center position. Be sure lever and pedal are returning completely and there is clearance between the two arms at the adjustment bolt on the tranny end. The short arm should have no pressure on in when the clutch is engaged.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 12-07-2007, 09:10 AM
h20cooled7's Avatar
ok so im in the market for a fatter pressure plate spec or center force? i heard good things about centerforce and bad things.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-07-2007, 09:23 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
KEP stage one or two is your friend here.
Old 12-07-2007, 03:12 PM
h20cooled7's Avatar
is the KEP stage one good for the street and will it handle 500 hp? do you know a dealer or website
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-07-2007, 03:36 PM
A fellow Pelacanite
NathanUK's Avatar
Yes yes yes Although you might want to get a stage 2 to be safe if you are going to make 500lb/ft of tq.
http://www.kennedyeng.com/porsc_pp.htm
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 12-08-2007, 05:19 AM
h20cooled7's Avatar
where can you purchase KEP from?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-08-2007, 02:27 PM
A fellow Pelacanite
NathanUK's Avatar
http://www.kennedyeng.com/index.htm
or
www.imagineauto.com
Old 12-08-2007, 03:29 PM
h20cooled7's Avatar
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-10-2007, 05:15 PM
