DSPTurtle's Avatar
Turbo Tank Drain Plug Torque
Hey Guys,
For all my fellow anal retentive DIY Turbo friends... anyone have a clue on the torque spec for the turbo oil tank drain plug? I have not read in any of the books where anyone actually drains it but I figure someone on here must be at least as crazy as me. Thanks in advance!!!
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 12-08-2007, 12:33 PM
sudo apt-get purge 930
equality72521's Avatar
Are you talking about the oil reservoir under the oil filter?
--clutch-monkey
Old 12-08-2007, 01:05 PM
DSPTurtle's Avatar
Nope... the little tank under the turbo that uses a 6mm allen wrench. It is an M12 but no one seems to make the exact washer either so I ended up with this relatively large OD but M12 ID aluminum washer and want to make sure I torque it correctly.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 12-08-2007, 01:40 PM
A fellow Pelacanite
NathanUK's Avatar
I don't have that one either and I have the Factory Workshop Manuals.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 12-08-2007, 02:18 PM
Yeah, I just got done looking through mine with no luck.
--clutch-monkey
Old 12-08-2007, 02:19 PM
cycling has-been
bkreigsr's Avatar
I would go relatively low, like around 14 ft lbs.
I think the fitting in the tank is brass with a tapered thread.
The PO of my car had it overtightened and it was heck to remove.
Bill K
Old 12-14-2007, 10:24 AM
Crotchety Old Bastard
RarlyL8's Avatar
I don't sweat things like that. Tighten it hand snug and check for leaks then give it an extra tweak. If you drain it with every oil change you'll never have a problem with it sticking shut.
Old 12-14-2007, 12:39 PM
resident samsquamch
sand_man's Avatar
Agreed! You just sort of develop a "feel" for this kinda stuff. I know that sounds like a slam on the original poster, but I don't mean it as such...just use your best judgment and you should be fine. I have found that in most circumstances the "gorilla grip" approach is a bad thing when tightening fasteners on these things (lug nuts not withstanding). Now when you're talking about rod bolts, head studs, case fasteners....then yeah, you gots to bust out a damn fine torque wrench!
-jeff
Old 12-14-2007, 02:33 PM
