wmunchovie's Avatar
valve recommendations?
Hello All,
I am looking for recommendations for intake, exhaust valves, seats, guides and possibly springs; I have a set of 3.3L twin plug heads and I want to go back with something dependable but not too exotic. This is a street 930 going to the deli a couple of times per month but I need for the seats to stay glued in
Thanks for the feedback!
Munchovie.
Is 13 lucky or unlucky ?
Old 12-10-2007, 08:03 PM
930gt-40r's Avatar
I would go with some Ferrara valves- people seem to have good luck with them- maybe 1mm up on the intake side?
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 12-11-2007, 06:38 AM
Wo ist die Rennstrecke?
DonE's Avatar
What's wrong with OEM for your application?
Old 12-11-2007, 02:58 PM
wmunchovie's Avatar
Not ruling out OEM at all, rather just trying to get everyone's experience with different valve related components; the last time I used OEM I wound up with pitting of the exhaust valves, and some splitting of intake valves with hairline cracks Im not too sure what is causing these maladies so I want to try and do my research so they are avoided during my current rebuild.
So my friends: step up and tell me the valves you like and why ( even links if you have them handy )
Thanks!
Munchovie.
Old 12-11-2007, 03:15 PM
DonE's Avatar
OK
I use stock valves. The seats and guides were installed by JB Racing and I didn't ask them for anything different other than what they suggested for my 80% street / 20% DE.
As for valve springs, I use JB Racing springs - the GTII EVO cam and the stock 930 springs would bind.
Old 12-11-2007, 04:35 PM
i am thinking the factory valves are SS ?
i know that the ferrea valves are , and if the OEM ones aren't then you can see some benefits from the difference of alloys alone as SS valves will withstand heat better ... also a 1mm oversized valve will benefit in low cam lift situations (more air coming in) , thus giving you a better low end torque.
the real benefits are in the valve seat and porting out the stock intake/exhaust ports .
if you get aftermarket valves and a good 5-angle valve grind you can see some benefits on the overall powerband, i believe the stock valve seat is a 3-angle . porting will gain alot more top-end but you might loose some low-end/mid-range torque if you really hog them out . the more agressive the valve grind the more flow you will see but it will also wear the valve seat out faster and vice-versa.
on other watercooled engines , i have seen a big gain out of grinding the valve guides flush with the head , granted that the engine is watercooled it had a margin of safety, on an aircooled engine this may not be very wise , uless its a race engine that will be torn down. consistently .
end rant..
Old 12-11-2007, 05:10 PM
also i might add that stiffer valve springs are imperative . using an aggressive cam grind means that at high rpms you will get valve float . also on high boost situations you may see the same results . both are bad if you want to make the most power.
and if remember correctly the intake valve is much bigger than the exhaust valve . on turbo cars you want to get most exhaust gas out since it is what drives the turbo so i would suggest to go over sized on the exhaust valve if you can only do one . both valves are very close tho and you may not be able to go oversize at all.
Old 12-11-2007, 05:25 PM
930gt-40r's Avatar
Munchovie- after watching your video I am defenatly all for you using STIFF valve springs- I got the Porsche motorsport springs in my car.
Kris @ Tech9
86' 930/GT-40R Sold
Old 12-12-2007, 06:06 AM
wmunchovie's Avatar
Well, I must admit that maybe I was just a tad mean to the tach that day But you are right, I think with the flat top pistons and beefier cam that I don't want my intakes doing an automatic piston relief job....
Stiffer valve springs it is then...
munchovie.
Old 12-12-2007, 01:39 PM
