resident samsquamch
sand_man's Avatar
JB Racing has a nice solution as does Supertec Performance:
Twin-plug ignition
-jeff
Old 12-13-2007, 05:11 PM
resident samsquamch
sand_man's Avatar
I'm running the Electromotive XDi crank fired system that Clewett sells.
-jeff
Old 12-13-2007, 05:15 PM
F350Lawman's Avatar
When the turbo is pumping it sucks in a tremendous amount of air;
the air cleaner that is on the 930 is way too small; one would be way better off with the stock air box - it will let a higher CFM flow into your CIS; also one really needs to allow the case to vent....
Thanks,I know it looks small, however...I am running the same filter several others have. Others have dynoed their cars with and w/o similar setups with no change in power numbers. That being said, my car now has a K&N that is the same diameter but 1 1/2 times as high.
I think it will flow as much or more than the stock box with the little -bitty hole. I really only changed for engine access, but I wil monitor performance and AFRs
1987 930 - K27 7200 / DAS Full Cage / Blownsix Intercooler / BB Headers / Zork Tube / Tial 46mm / Adjustable WUR / RPM Activated Solenoid / Open Element Air Intake / Smart Racing 27mm Sways / 24 and 33mm Torsion Bars / Adj. Spring Plates / Wevo Strut Brace / Monoballs / Tow Hooks / Oil Cooler Scoop / Brey Krauss Harness Truss / Race Seats / XD-16 AFR Guage/ 17" Kodiak Racing Whees and Nitto NT-01 255/315s
Old 12-13-2007, 08:07 PM
Forced Induction Junkie
WERK I's Avatar
Originally Posted by h20cooled7 View Post
are twin plug distributors rare and expensive or is there some aftermarket applications?
Most of us that are running twin-plug, are running wasted spark. DonE is running EFI with EDIS wasted spark, I think. Others are using Megasquirt EFI with EDIS wasted spark and me, bringing up the rear, Electromotive HPV-1 twin plug crankfire ignition. There may be other types......
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 12-14-2007, 05:11 AM
David's Avatar
Another satisfied Clewett wire user here. I bought one of the first sets and due to long drawn out project it took a while to get them installed and realize there was a problem. Clewett kindly replaced them even with the time lapse and the new wires are great! And I've had them on and off many times.
2014 Cayman S
2011 Cayenne Turbo
Old 12-16-2007, 07:00 AM
