930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Question are magnecore wires ok for a 930?
im just throwing it out there and trying to get other peoples opinions
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-11-2007, 05:51 PM
F350Lawman's Avatar
I have had them for the last 5000+ miles, seem good to me.
1987 930 - K27 7200 / DAS Full Cage / Blownsix Intercooler / BB Headers / Zork Tube / Tial 46mm / Adjustable WUR / RPM Activated Solenoid / Open Element Air Intake / Smart Racing 27mm Sways / 24 and 33mm Torsion Bars / Adj. Spring Plates / Wevo Strut Brace / Monoballs / Tow Hooks / Oil Cooler Scoop / Brey Krauss Harness Truss / Race Seats / XD-16 AFR Guage/ 17" Kodiak Racing Whees and Nitto NT-01 255/315s
Old 12-11-2007, 06:45 PM
wmunchovie's Avatar
When the turbo is pumping it sucks in a tremendous amount of air;
the air cleaner that is on the 930 is way too small; one would be way better off with the stock air box - it will let a higher CFM flow into your CIS; also one really needs to allow the case to vent....
munchovie.
Is 13 lucky or unlucky ?
Old 12-11-2007, 06:57 PM
h20cooled7's Avatar
so do they come with the grounding braids ,or I dont need them?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-12-2007, 04:50 AM
resident samsquamch
sand_man's Avatar
The Magnecors do NOT have the grounding braids. When I still had the stock ignition system, I briefly ran Magnecors with good results. I went to Electromotive twin-plug and got the Clewett wires, which I really love.
-jeff
Old 12-12-2007, 06:21 AM
Forced Induction Junkie
WERK I's Avatar
+1
The Magnecores are very good wires. It's the spark plug boots that suck----really a piece of crap. Pricey wires with a cheap-a$$ boot. Ask me how I really feel!
Clewett builds a nice wire with good boots at an attractive price.
The braids were added back then when the engineers at Porsche were trying to fix the back-fire issue with the CIS systems. They thought there was some spark crossfire issues across the high tension leads. Little did they know that the problem was in the Bosch system!
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 12-12-2007, 06:51 AM
h20cooled7's Avatar
ok 1 more question who deals clewett and are they better than stock?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-12-2007, 07:21 AM
WERK I's Avatar
Yes, better than stock.
http://www.clewett.com/
Dave
Old 12-12-2007, 07:23 AM
h20cooled7's Avatar
I'll check em out, Thank You!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-12-2007, 07:30 AM
resident samsquamch
sand_man's Avatar
Yes the Clewetts are better than stock. Richard Clewett is also a really nice guy to deal with! And I agree with Dave's comments about the Magnecore boots. The Clewett boots/connectors have a nice "click" to them when you've properly seated them on the spark plug.
-jeff
Old 12-12-2007, 07:32 AM
Lurkasaurus
turbocarrera's Avatar
I bought a set of stock wires(Beru) about 8 years ago - I test them every once in a while and the leakage is basically the same as new. I might buy Clewetts when I need wires and can get a deal but these Beru wires are great - good boots and ground strap and they give the nice click too.
Tony '77 930
"Objects in mirror are losing"
"Oh cock..." - James May
Old 12-12-2007, 08:13 AM
pdqcarrera's Avatar
What size Clewetts are you running? Do they come precut to fit and what did you do for spreaders?
Cheers,
PDQ
Old 12-12-2007, 11:48 AM
Wo ist die Rennstrecke?
DonE's Avatar
You'll need to ask Richard to install the top shelf connectors/boots. I ordered the Clewett wires (which are either magnacore or taylor wires wrapped in clewett logo'd heat wrap) with standard boots, and the rusted to the point they failed. I then installed the magnacore stainless connectors and haven't looked back. The clewett wires are still performing well and are recommended. I think they are 8mm.
Old 12-12-2007, 04:12 PM
A fellow Pelacanite
NathanUK's Avatar
How does one test these wires?
I only know of the look at them in the dark trick or the fact that they have rubbed away or the connectors are corroded.
TIA
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 12-13-2007, 08:32 AM
h20cooled7's Avatar
another good trick to test for leakage is table salt water and spray bottle , the saltgive you a better path to ground!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-13-2007, 09:07 AM
resident samsquamch
sand_man's Avatar
As for the Clewett wires, there was a point earlier on in his production run, where I think there were some corrosion/QC issues...it was hit or miss, not all of the wire sets during this time had problems. HOWEVER, these issues have been resolved.
I'm not sure what Clewett uses for his base wire, but mine have a cloth-like material on them (probabaly something synthetic), running the length of the wire, with the shrink wrap Clewett logo that DonE described. Maybe there's a Magencore wire under this casing? Not sure...
-jeff
Old 12-13-2007, 09:10 AM
A fellow Pelacanite
NathanUK's Avatar
That makes sense as I know that clean water is not conductive, some people think I mad when I tell them this
Old 12-13-2007, 01:40 PM
DonE's Avatar
Use an OHM meter to test resistance. Clewett should be able to tell you what the resistance per foot is, so do some simple math. Corrosion will increase resistance. On a wasted spark system like mine, resistance is important.
Old 12-13-2007, 02:48 PM
930gt-40r's Avatar
+ 2 on the clewwetts- just instaled them on a 12 plug sys. VERY nice.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 12-13-2007, 03:16 PM
h20cooled7's Avatar
are twin plug distributors rare and expensive or is there some aftermarket applications?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-13-2007, 04:59 PM
