Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Macht Schnell
les_garten's Avatar
Heat Exchanger Orange Hose
Hi,
This seems like a stupid question, but I don't know the answer so here goes. I bought some of the Orange High Temp Heat Exchanger hose when I rebuilt my motor. I had to trim the lengths down which means I had to clip the wire circling the hose. Now I have this length of wire that sticks out on all my hoses like a scalpel and occasionally lays my hand open.
What's the remedy for this?
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 12-13-2007, 02:26 PM
A fellow Pelacanite
NathanUK's Avatar
Turn just over an inch of the strand of wire inwards (bend it approx 90 degrees where it comes away from the plastic) so it is inside the tube, bend it again if needed so the end does not rub on the tube.
Firstly though fold the very end of the wire over on to itself first about 1/8" like you can for lockwire ends, this is so it is not sharp.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 12-13-2007, 02:50 PM
Macht Schnell
les_garten's Avatar
I'll give that a shot. For some reason when you clip that wire it wants to stick straight out.
Thanx!
Les
Old 12-13-2007, 04:05 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I just tuck the cut wire back in the hose enough so that it won't pop out. You may need to bend it a little bit so that it works with the hose.
Old 12-14-2007, 01:05 PM
A fellow Pelacanite
NathanUK's Avatar
Yep, that is what I am explaining.
Old 12-14-2007, 01:34 PM
Brando
quattrorunner's Avatar
Stitches if it's real bad, maybe you could use a butterfly bandage?
Turbo powa!
1977 911s. it's cool
Old 12-15-2007, 10:51 PM
7.0:1 > 11.3:1
What Nathan describes the exact technique aviation mechanics use for installing this hose (Aeroduct).
Old 12-16-2007, 06:52 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
