Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Cat and 1st 1/2 Muffler Glowing Red
The stock 88 930 was running fine all day yesterday - put 100+ miles on it. Took it on a three mile drive tonight. When I pulled over I noticed it was idling real high - about 2100 rpm. I then got out of the car and noticed the engine was clicking, tinking and clacking - like it had just been driven real hard for awhile and was hot. I took a look at the back of the car and noticed the right side of the muffler was glowing red but not bright red. I could also see that the cat was red as well.
The temperature gauge was reading normal.
Anyone have any ideas of what might be going on?
Thanks-
Craig Backer
Old 12-13-2007, 08:21 PM
Same thing happened when we put a SC on my friend's Vette. Apparently the AF ratio was off and it was running lean.
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 12-13-2007, 08:36 PM
Craig,
Normally when you see this the fuel mixture is off. In most cases it is rich. It's not a good idea to drive the car in this condition. If the cat gets too hot, you can ruin it.You need to get it checked at a shop.
JR
Old 12-14-2007, 02:47 AM
beepbeep's Avatar
AFR's are out of whack or dizzy jumped a tooth and ignition is way retarded.
Thank you for your time,
Old 12-14-2007, 05:10 AM
onboost's Avatar
+1 Goran...
RGruppe #180
Old 12-14-2007, 06:09 AM
Me like track days
Craig 930 RS's Avatar
Plus Dos -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-14-2007, 03:36 PM
