Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Macht Schnell
les_garten's Avatar
K27 HF2 Question
Hello,
I just fitted a K27 HF2. Nice Turbo! I was wondering where boost starts and where it is full on for most folks that have one of these? I had a K27 7200 before and it seems like I lost about 500 RPM. I kinda expected it though.
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 12-15-2007, 07:42 AM
David's Avatar
Mine's pretty much full boost at 3500, but it's climbing fast at 3000.
2014 Cayman S
2011 Cayenne Turbo
Old 12-15-2007, 10:25 AM
Macht Schnell
les_garten's Avatar
Thanx! I noticed your sig there. I have a '92 R100RT
Les
Old 12-15-2007, 10:48 AM
David's Avatar
Les
Something else I can blame Pelican for .
I always loved the boxer engine, so I bought it when my 930 was down so I had something to go fast on. I think my car's faster now!
2014 Cayman S
2011 Cayenne Turbo
Old 12-15-2007, 11:46 AM
Macht Schnell
les_garten's Avatar
Mine's the last year of the classic boxer. I rode one like yours before, and it's considerably more civilized than mine is, yours is a lot smoother and the EFI is very nice.
I punched my motor out to 1100, bigger Intake and Exhaust valves. Little more compression, lightweight wrist pins. Satge 4 Flowed and CC'd heads, Dual plugged, balanced and blueprinted motor, Cam'd, high ratio Crane Forged AL rocker arms, 40mm Mikuni Flatslides and some more I probably forgot about.
When I wick my throttle, the bike pulls a wheelie and breaks the rear tire loose. Definitely a serious Old R-Bike. Need to do some fairing and Paint on it presently due to a crack in the fairing from a low speed drop.
Thanx for the info!
Les
Old 12-15-2007, 12:09 PM
David's Avatar
Sounds like a cool bike. I worked at an independent BMW shop in Austin in school that built some pretty wicked boxers so I've had an appreciation for them for a while.
Ever so often the idea of going a little wild on the engine crosses my mind, but fortunately the idea fades pretty quickly.
2014 Cayman S
2011 Cayenne Turbo
Old 12-15-2007, 03:24 PM
Macht Schnell
les_garten's Avatar
I drove my 930 and laid into the boost for the first time today with the HF2. Man, it's nice to feel the tires bust loose again! When my 930 was stock, after a few years of driving it, it just didn't have the same performance. I asked the guy who was wrenching my car, he said it feels like a stock 930. But it didn't for me.
When I decided to rebuild it and tore it down, every compression ring on all cylinders was broken. They just fell out in a zillion pieces. It was amazing how well the car ran with smashed rings. I have an adjustable boost controller on it at the time and am sure that didn't help anything! Even with all the rings broken the cylinders and pistons were perfect.
Les
Old 12-15-2007, 03:53 PM
Me like track days
Craig 930 RS's Avatar
EFI perhaps needs adjusted? Just a dumb non-EFI guy guess.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-15-2007, 06:14 PM
Me like track days
P.S. If you want a real treat, go to Les' rebuild pictures http://www.lesgarten.com/pix/porsche/
Great stuff, Les!
Old 12-15-2007, 06:21 PM
Macht Schnell
les_garten's Avatar
Great stuff, Les!
Craig,
You must have a screaming Internet connection to DL those PIX. I made most of them pretty big for detail.
Thanx for the compliment. Wayne Dempsey, His Book, and Pelican parts made it possible for me to do this.
Les
Old 12-15-2007, 07:20 PM
David's Avatar
It is nice having all that boost isn't it .
I just feel a little bad for my fellow motorists. Can I help it if my car wants to lay down big long black streaks when I'm passing .
2014 Cayman S
2011 Cayenne Turbo
Old 12-16-2007, 06:53 AM
Macht Schnell
les_garten's Avatar
The Car corrupts the driver!
Les
Old 12-16-2007, 06:59 AM
I live in West Palm, and have a venetian blue '87 930.
I also have a '75 BMW R90S that is bored to 980cc, dual plugged, CC products lightened flywheel and high lift rockers, and Ti valve spring retainers.
It still has the origonal 38mm dellorto carbs with different mixture needles and main jets.
It also has a CC products cast upper triple clamp, braced swingarm, 40mm stainless dual exhausts with supertrap mufflers, telefix lower fork brace, progressive suspension front springs and koni's in the back.
Unfortunately it and a Honda 500 intercepter have been in storage for a while now and I havn't ridden them in years.
I was driving south on US 1 in Tequesta around the first week of november and sitting at the light at county line road and some one came by in the right lane and turned right onto county line rd.
The guy driving seemed enthusiastic about my 930 and I have wondered if it was someone that might be on this message board.
Old 12-21-2007, 03:14 PM
WydRyd's Avatar
Les
Remember, the larger the compressor wheel = the more inertia = more lag. However, you'll be able to flow more power up top and the turbo won't run out of "puff" in the upper RPM band.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 12-21-2007, 03:36 PM
Macht Schnell
les_garten's Avatar
Hi,
Wasn't me. I had the Motor in my Beemer done by CC products. I just took off the 2:1 supertrap off of it and bought some Keihin's for it, haven't put them on yet.
Good stuff here.
Les
Old 12-21-2007, 04:17 PM
Macht Schnell
les_garten's Avatar
Hi, Actually after stopping up some leaks and tweaking around with it, I'm not sure I lost as much as I thought. Maybe 2-300 rpm. Definitely breathes better than the K27 7200 I had in the Midrange and up top. Very happy with it. I need a boost pipe for it though. I still have the AL adapter and it's got to go.
Les
Old 12-21-2007, 04:20 PM
Crotchety Old Bastard
RarlyL8's Avatar
Les, If you're using a C2T intercooler I have a stock up-pipe I'll sell. Shoot me an e-mail.
Old 12-21-2007, 08:29 PM
Macht Schnell
les_garten's Avatar
Hi RarlyL8,
I have an Andial(Garrettson) IC. My stock boost pipe is close. I have a few problems though.
1) I don't like the AL adapter with 2 O-rings seals in play with the K27. The first K27 I wittled the throat of, I ground off more than the present one.
2) I have a 3.2 Manifold, cut and flipped, so the angle from the outlet throat of the IC to the Throttle Body is a little different than stock. This makes the stock boost pipe have a slight gap at the top and bottom. I just don't like the O-ring seal deal. I would prefer big SS hose clamps and silicone hose transitions.
Les
Old 12-21-2007, 08:45 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
