manifold eliminator
anyone sell or know of pop off manifold manifold eliminator..the adapter to use stock style intercooler..with out using pop off valve manifild???????????
Old 12-17-2007, 07:12 AM
Most (all?) of the aftermarket 930 intercoolers eliminate that manifold and replace the recirc function with a 965 valve instead.
'77 S with '78 930 power and a few other things.
Old 12-17-2007, 09:06 AM
E-85 sippin drunk
turbobrat930's Avatar
And Spuggy is right, most of the aftermarket I/C's replace the factory valve with the one you are looking for. I would not use the stock I/C at all!!!! It is not good at keeping the inlet temp down... I could probably pee on the motor and make the intake air cooler than the stock piece... FWIW, get a different I/C.....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 12-17-2007, 10:08 AM
