Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
e170drvr's Avatar
OK, Got this thing fixed last night. Ended up doing a timesert for this thing. Turned out really nice, and solid. Hopefully it will hold up. Thanks to all that offered advice during my little "emergency"
Eric
87 930
Old 01-05-2008, 02:12 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Good news e170driver!
I would have prefered the Timesert, but didn't have time before I had to leave for the track (and they just aren't available around here). It has held up for several years and engine drops though.
Old 01-05-2008, 07:05 PM
Just read this thread,,well done and although the job is finished!..another method i use is to drill like you had done leaving just the shell of the original broken bolt then if the hole diameter is large enough to get a junior hacksaw blade in there you can cut a hacksaw blade thickness slot down through the thread until it breaks through the outer broken thread,,then you should be able to pick the thread out with a scriber etc because the broken thread shell has somewhere to go because you have split it!!
Just a idea if anybody comes across this again!
Old 01-06-2008, 03:17 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
