-   -   Uh, oh, now I'm F@cked. (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/384619-uh-oh-now-im-f-cked.html)
e170drvr 12-29-2007 04:23 PM
Noticed lots of vibration from drivetrain lately went to check the transmission mounts, and one side was sagging. put a jack under trans to take the pressure off the mounts, when I tried to loosen the bolt it sheared off. now I have part of the bolt stuck in the trans. Any ideas on how to remove the rest of the bolt that is stuck in there? Only thing I can think of is to drill it out of there. Crap!
Eric
87 930
e170drvr 12-29-2007 04:28 PM
Sorry this thing posted twice. don't know how to delete the second one
kas930 12-30-2007 08:10 AM
I'm afraid that if it sheared off flush, then drilling and using an easy out might be your only option. If you have to drill, I would use a reverse drill bit that sometimes will loosen the broken bolt while your drilling.
Komenda Fan 12-30-2007 08:40 AM
I'd second the idea of using an easy out, but be careful. Make sure you are centred on the bolt, which can be difficult to do. Go real slow to make sure you don't make an error.
NathanUK 12-30-2007 02:51 PM
Use a hammer and a punch to make a dent in the centre of the bolt you are drilling. makes getting it in the centre a little easier.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
