Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
e170drvr's Avatar
Uh, oh, now I'm F@cked.
Noticed lots of vibration from drivetrain lately went to check the transmission mounts, and one side was sagging. put a jack under trans to take the pressure off the mounts, when I tried to loosen the bolt it sheared off. now I have part of the bolt stuck in the trans. Any ideas on how to remove the rest of the bolt that is stuck in there? Only thing I can think of is to drill it out of there. Crap!
Eric
87 930
Old 12-29-2007, 03:23 PM
e170drvr's Avatar
Sorry this thing posted twice. don't know how to delete the second one
Old 12-29-2007, 03:28 PM
kas930's Avatar
I'm afraid that if it sheared off flush, then drilling and using an easy out might be your only option. If you have to drill, I would use a reverse drill bit that sometimes will loosen the broken bolt while your drilling.
Old 12-30-2007, 07:10 AM
Komenda Fan's Avatar
I'd second the idea of using an easy out, but be careful. Make sure you are centred on the bolt, which can be difficult to do. Go real slow to make sure you don't make an error.
1977 Turbo Carrera Black on Red #411
1987 951 Black on Black - sold to make room for the 930
1972 911 2.7 (RS P's and C's, solex camshafts, Weber's, ST suspension) - I regret selling her every single day....
Old 12-30-2007, 07:40 AM
A fellow Pelacanite
NathanUK's Avatar
Use a hammer and a punch to make a dent in the centre of the bolt you are drilling. makes getting it in the centre a little easier.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 12-30-2007, 01:51 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
