Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Metal Guru
911nut's Avatar
Anyone Ever Built a Stroker Turbo Motor?
Seems like maybe using a 964 crank would yield a motor with better off-boost torque.
Anyone ever tried this?
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 12-30-2007, 11:12 AM
E-85 sippin drunk
turbobrat930's Avatar
DonE has... He is using the 964 crank with 98mm P&C's..... seems to run like a bat out of hell!!!
I am running the same 98mm P&C's that Don is running, but I am using my stock 3.3L crank. I sent my crank away to CCR ( Armundo) and had is stroked to 78.8 or 78.4 ( cant remember which one). He stroked it by offset grinding the rod journals, coupled with the 98mm P&C's, it is close to a 3.6L. I used custom Pauter rods.... and Clevett Nascar bearings... JB Racing did this for me...
I have yet to have it running, as I need to make a set of custom headers for the car...and get a few parts...but the motor is together.... see this post for assy....
another 930 rebuild....It is FINALLY coming together!!!
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 12-30-2007, 12:53 PM
Metal Guru
911nut's Avatar
That's just gorgeous!
What do you estimate the output will be?
Paul B.
'91 964 Turbo
Old 12-30-2007, 04:09 PM
930gt-40r's Avatar
I got a 3.6 turbo crank in my 3.3 motor (close to 3.4 now) with pauter rods and stock piston/cyls.
I made 500 to the wheels on a hot day and a spinning clutch. I ran 18 psi and about maybe 20 degrees of timing. The car has a some more bottom end grunt and hits boost a little quicker.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 12-30-2007, 04:25 PM
Wo ist die Rennstrecke?
DonE's Avatar
The stroked crank and the 8.0:1 compression ratio makes very nice low end torque and great city driving.
Old 12-30-2007, 05:23 PM
E-85 sippin drunk
Thanks!!! I built it with a goal of 600 crank HP in mind.... but the final number is not the most important thing.. HP and TQ that is usable is more important to me... Hopefully with all of the mods/ parts/ etc that I have done to this motor, I will have gained more usable HP and TQ than I had before.. ( I was at the limit of the CIS system before I spun the rod bearings)...
but yes, the bragging rights would be nice... but not nessasary....
and a shamless plug for DonE... without his help.. I would be no where near where I am today..little lone have learned much more than what I knew before this happened.. THANKS!!!
Old 12-30-2007, 05:26 PM
onboost's Avatar
anymore status on that engine and its build?
Don, how about a pic of the car?
RGruppe #180
So many cars..so little time!!
Old 12-30-2007, 08:16 PM
Both Ollie (OMS930) and I have stroker motors utilizing 3.6 RSA cranks and we are also north of 550rwhp at .9 bar. The engines were both built by Speedwerks of North Carolina.
Old 12-30-2007, 09:39 PM
Metal Guru
911nut's Avatar
We (the Detroit based Turbo Pelicans) will have to arrange a get-together in the spring to see your car, if you wouldn't mind.
Paul B.
'91 964 Turbo
Old 12-31-2007, 05:00 AM
That would be fun, as soon as the weather breaks.
Old 12-31-2007, 02:08 PM
3.6 crank here and 98mm pistons
Old 12-31-2007, 03:42 PM
930gt-40r's Avatar
Must be some hot $hit mechanic putting that together...
Kris @ Tech9
86' 930/GT-40R Sold
Old 12-31-2007, 04:18 PM
Well the infamous bling bling runs so he must be a saint or something!
Old 12-31-2007, 04:27 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
