Originally Posted by Jeff Alton View Post
thanks fellas.
I will keep everyone posted. You turbo guys, are you looking to run 315's on the rear or something smaller?
Ben, yours will be easy, I think we can just add an outer shell that will be 2 inches wider than the standard carrera 9.0 if you have 2 inch spacers.....
Cheers
Jeff,
Please add me to the list of interested folks. I'll be going for the same specs as Ben - 9&11x17 set up for a '77 911 S converted widebody.
Thanks!
Old 01-15-2008, 08:06 AM
+5 on the deep dish. I love the wide wheel look from the rear, and the side!
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 01-15-2008, 10:57 AM
jay71's Avatar
Jeff- what's the status on the wheels project? Spring's closing in and I'm itchin' for a set of 9 & 11x17's w/RSR finish!
Jay
'86 930
'60 Land Rover Series II SWB
Old 02-27-2008, 04:59 PM
Jeff Alton's Avatar
Comming, really they are. This is process is taking longer than I thought, but I will keep folks up to date as info comes in. I will post a pic as soon as I can.
I should know more tomorrow about when I can get the prototype off to STL for load testing.
Cheers
jeff@turn3autosport.com
997 S 4.0, Boxster 2.7, Boxster S race car, 958 Cayenne TT, VW GTI 2.1 TSI, Mini Cooper S JCW, Cannondale Supersix EVO SRAM RED E-tap, Cannondale Slice SRAM RED E-tap
Old 02-27-2008, 10:25 PM
Crotchety Old Bastard
RarlyL8's Avatar
What is your target price point?
Old 02-28-2008, 06:54 AM
Me like track days
Craig 930 RS's Avatar
Please publish your test results, as durability is going to be a concern for a 300-400hp 930 -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-28-2008, 08:17 AM
Jeff Alton's Avatar
I publish the results for sure.
Brian, the first production run will be priced at or below the price of the Lindseys. After that I need to talk with those that will be marketing the wheels and come up with a figure. That said, I think the what the market will pay is pretty well established. Look for them to remain priced comparable to a Lindsey.
Cheers
Old 02-28-2008, 01:41 PM
Jeff Alton's Avatar
Okay,
Just finishing up the prototyping on both the 17 and 18. For an 11.0 inch rear what backspace are you guys with turbo chassis looking for?
Cheers
Old 03-07-2008, 11:31 AM
efhughes3's Avatar
Okay,
Cheers
I'm guessing you didn't need to bother to ask about Carrera/SC bodies, 'cuz you've already got that worked out. And those protos will be done first.
Errrr, ahhhhh, ummm, right????
Ed Hughes
1995 993 Coupe "Sapphire"
Old 03-07-2008, 12:53 PM
resident samsquamch
sand_man's Avatar
Okay,
Cheers
I know this is an overly simplified answer, but I just want to be able to bolt them on...don't want to dick around with spacers or longer studs or rolling fenders or removing anything. In other words, whatever offset fits an '87 soon to be at Euro ride height.
-jeff
Old 03-07-2008, 03:38 PM
Me like track days
Exactly.
Installing 315s to fit (BFG TA KD) are a plus also. 275s up front would be nice, but 255s ok too -
Old 03-07-2008, 03:50 PM
Jeff Alton's Avatar
I built turbo wheels that take a 315, they were 11.5's. I was hoping those who already run this size wheels could provide the backspace numbers so I can cross check.
Cheers
Old 03-07-2008, 04:20 PM
Driver
Noah930's Avatar
What he said.
1990 Black 964 C2 Targa
Old 03-07-2008, 09:19 PM
Smart quod bastardus
fredmeister's Avatar
I would like 8.5 or 9 fronts and 10.5-11.0 inch rears in 17 inch size.
Eliminating the factory spacers is a plus but no big deal.
As far as actual backspace required, Jeff can't you just figure out what would be required to get the outer rim more or less flush with the fender lips. This would give the best look and widen the track of the car. This is best done on an actual car using a known quantity rim to measure from and determine the required offsets from there. Unless someone can give you hard numbers, you might have to provide some examplesettings or do it yourself.
I don't know how bad this would effect front end geometry but the rear should not matter.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 03-07-2008, 09:42 PM
Jeff Alton's Avatar
Yes I can do that, and have. I have built many wheels to fit 930's. However, it seems everyone of my customers wanted a slightly different spec. So I was trying to see if there was a general agreement about what spec would be best.
I will build them to eliminate the spacer as the wheel then will have a deeper "dish" to is which I think is what most are after.
Cheers
Old 03-08-2008, 06:29 AM
For my 930 with non-floating discs/ without spacers
Two 17x9 15mm offset, 130 backspace (same as porsche 16x9)
Two 17x11 0mm offset, 140 backspace
Old 03-08-2008, 11:24 AM
resident samsquamch
sand_man's Avatar
Yes, I guess I'd be willing to sacrifice the factory spacers to gain an even deeper dish...
-jeff
Old 03-08-2008, 11:27 AM
jay71's Avatar
+1
Jay
'86 930
Old 03-08-2008, 01:04 PM
pdqcarrera's Avatar
... I will build them to eliminate the spacer as the wheel then will have a deeper "dish" to is which I think is what most are after.
Cheers
Absolutely ... the deeper the better!
Cheers indeed!
Old 03-08-2008, 01:55 PM
Rory Mckenna's Avatar
not too deep.. If they get too deep dished they start to look kind of stupid...a good 6" is what looks best IMHO..
" that's what she said"
Old 03-08-2008, 04:43 PM
