A fellow Pelacanite
NathanUK's Avatar
Just a thought, you could remove the spacer and fit the new wheels with longer wheel nuts.
I'm pretty certain on my car that it has been fitted with shorter studs and the spacer removed.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-09-2008, 12:18 PM
e p slick's Avatar
Another Lindsey Picture
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 03-13-2008, 05:14 PM
purplehaze's Avatar
Originally Posted by Jeff Alton View Post
...For an 11.0 inch rear what backspace are you guys with turbo chassis looking for?
Jeff,
For reference, I use a set of 18" CCW's, no spacers (no factory rear spacer either) with the following:
9" 31mm offset, 6-1/4" backspacing
12" zero offset, 6-1/2" backspace
Just bolt on and go, no extra long studs necessary.
Sounds like a great project - with drooling buyers.
Good luck!
Glenn
87' 930TT
Old 04-18-2008, 12:43 PM
wcc wcc is offline
wcc's Avatar
Picked up some future Lindsey's at a swap meet today....
Bill
Old 04-19-2008, 10:56 AM
Nice find! 16x6's right?
Old 04-21-2008, 06:35 AM
wcc wcc is offline
wcc's Avatar
Yup, all four. Sent them out to Mike today....
He did say he couldn't make the 8.5 fronts that I wanted but an 8 would work with the 235/45 that I was planning on using.
Bill
Old 04-21-2008, 02:56 PM
What size for the rears?
Old 04-21-2008, 03:37 PM
wcc wcc is offline
wcc's Avatar
I'm plannng on running:
Front: 235/45/17 on the 8" rim
Rear: 315/35/17 on the 11" rim
Bill
Old 04-21-2008, 03:44 PM
You might want to consider a 255/45 on a 9" wheel on the front if you are doing 11/315 on th back. You will have additional steering effort at low speeds with the 255, but when speeds increase I think you might have too much understeer with that 235 setup. I run 255's on a 9" wheel and I just finished my first trackday with that setup- I was very pleased with the cars handling and it didn't wash out on slow turns or push. Just something to think about.
I would also recommend a 6mm front spacer to push the front out closer to the edge of the wheel wells. If you do the spacers, you might as well change out the wheel studs to 6mm longer too (while you're in there). It's not mandatory, but it's a nice safety issue to maintain all your threads on the nuts.
Old 04-21-2008, 04:09 PM
wcc wcc is offline
wcc's Avatar
I'm pretty much settled on the 9" ones now. I really wanted the 8.5 but since he said he can't make them I have to go to an 8 or a 9. The 235 is the biggest I could run on the 8 and Mike said it's pretty narrow and I didn't want to run a 255 on a 9 because of possible rubbing, so I've settled on a 245/45 on the 9". I can always go bigger on the 9, which wasn't an option on the 8.
Bill
Old 04-22-2008, 03:27 PM
I'm interested in 11X17 and 9X17
What's would be the price ?
Old 04-23-2008, 12:59 AM
I only get rubbing at full lock- you just have to remind yourself to take a wider angle sometimes and don't go to full lock while parking. Occasionally a two point turn turns into a three, but it's no big deal. Anyway, I think you made a good decision on the 9's.
Old 04-23-2008, 04:04 AM
devoted Porschophile
lassedh's Avatar
Send a message via MSN to lassedh
Interessted in 9x17 and 11x17, if this wheel project still moves.
Old 08-18-2011, 02:45 AM
Jiu Jitsu Grappler
Rodsrsr's Avatar
Get ready for a loooong wait, but they are worth it; Here are my 17x9 & 17x11 Lindsays:
Jiu Jitsu Grappler
Know Gi / No Gi
1976 Turbo Coupe 3.2
2009 Carerra S 997.2 (SOLD)
Old 08-20-2011, 08:53 PM
vas930's Avatar
Sweet!
79 Silver 930 SOLD
Old 08-20-2011, 09:47 PM
I've tried few combos... I'm running 315x35 on 11x17 & 255x40 on 8x17. The best combo, even better than 9" & 11" IMO. However, and more important is the backspacing of the wheels which will determine what's spacers - if any - will be used maintaining the same suspension geometry.
Old 08-21-2011, 02:21 PM
pdqcarrera's Avatar
Would appreciate everyone advising their offsets & spacer situations. Seems a fair amount deviation. & would be nice to know details. Cheers!
BTW - I've been racing 245/40-17 (mostly Hoosiers) on 8" fronts for 20+ yrs to very good effect. Not saying better than a 9" but it does fit well & is quite responsive. FWIW - some race classes add points for rim width increases so this is a good compromise for a 2500# 911.
Old 08-23-2011, 07:14 AM
Jiu Jitsu Grappler
Rodsrsr's Avatar
No need for spacers, that's the whole reason for buying custom wheels. As far as offsets go, all I had to do was tell Mike what year the car was and what tire sizes I wanted to run.
Jiu Jitsu Grappler
Know Gi / No Gi
Old 08-23-2011, 07:29 AM
gumba's Avatar
I leave enough room for at least a 1/4" spacer to be able to adjust the wheel in the opening. Or measure all four fenders and have the wheel made to the narrowest front and rear opening.
Harold
'79 930/DP935
'68 VW 3.3 Turbo Crewcab
Old 08-23-2011, 09:28 AM
Tug68's Avatar
Not to get off subject but do you have to change the wheel studs or cut them down if you go no spacers?
Tim
87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost....
85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims.
Old 08-23-2011, 03:16 PM
