Grappler
Rodsrsr's Avatar
No, just use the steel open lugs.
Grappler
Know Gi / No Gi
1976 Turbo Coupe 3.2
2009 Carerra S 997.2 (SOLD)
Old 08-23-2011, 03:32 PM
E-man930's Avatar
I plan on bullnosing my studs... just a thought
Old 08-23-2011, 03:47 PM
gumba's Avatar
I milled the tops off the aluminum lugs nuts, like the photo. I have a couple sets of wheels with different offsets so it works for me. These are available from Rebel Racing.
Harold
'79 930/DP935
'68 VW 3.3 Turbo Crewcab
Old 08-23-2011, 04:09 PM
pdqcarrera's Avatar
Originally Posted by Miguel Antonett View Post
I've tried few combos... I'm running 315x35 on 11x17 & 255x40 on 8x17. The best combo, even better than 9" & 11" IMO. However, and more important is the backspacing of the wheels which will determine what's spacers - if any - will be used maintaining the same suspension geometry.
Miguel, will you share specifics of your wheels with us please?
Offset, backspace, spacers yes/no?
Old 08-29-2011, 03:09 PM
Garage Queen
PorscheGAL's Avatar
Just wanted to add some info, I run Lindsey rims with the following:
8 x 17 Fuchs Center Wheel, polished rim with semi gloss black center. 5.5" backspace
11 x 17 Fuchs Center Wheel, polished rim with semi gloss black center. 6.5" backspace
245 on front and 315 in rear. Toyo R888
You will need a 6mm spacer on the rear with this setup. I still get a little rub on brake caliber; a 7mm would be better.
Stephanie
My minions:'86 911 Targa 3.4, '87 930, '05 Lotus Elise,
'19 Audi RS3, '13 Focus ST, '16 Focus RS
Old 08-30-2011, 03:05 PM
Tug68's Avatar
Stephanie with you wheels did you do anything with the studs so you could use the original lugnuts?I love the setup you have on your car.
Tim
87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost....
85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims.
Old 08-30-2011, 04:20 PM
Garage Queen
PorscheGAL's Avatar
I had aluminum lugnuts ( the tall ones) , but some showed cracks and thread ware. I went with steel open lugnuts. I believe the previous owner cut the studs for whatever rims they had.
Stephanie
Old 08-30-2011, 04:39 PM
Tug68's Avatar
Ok thanks for the info
Tim
Old 08-31-2011, 05:09 AM
Just love white 930's!!! Stephanie, can you please post some more pics of your car!!!
Old 08-31-2011, 07:10 AM
