Macht Schnell
les_garten's Avatar
Scavenger Oil Return line
Hello,
Can you replace the line from the scanger pump to the oil tank with the engine in the car or do you have to drop the motor.
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 01-13-2008, 05:44 PM
stevie 77 930's Avatar
Les,
No need to drop the engine. Get the car in the air (jack stands of course) and climb underneath. There's one bolt attaching the line to the engine near the cooler. If your engine is dirty underneath, then the job is a little messy, otherwise not too difficult.
2018 GTS
2017 BMW 340I M Sport Package
1977 930 (recently sold)
1976 911S , 1973 1/2 911T, 1972 911E (long gone)
Old 01-15-2008, 09:41 AM
Macht Schnell
les_garten's Avatar
Originally Posted by stevie 77 930 View Post
Les,
Hi Steve.
Maybe it's not the scavenger line then. I assumed it was. I have a small oil line that is leaking at the oil tank. It is I believe the smallest line plumbed into the oil tank. It comes off the oil tank and starts running around the front of the motor towards the drivers side. I assumed that was the scavenger lind from the turbo scavenger pump.
Les
Old 01-16-2008, 10:32 AM
Les,
I think we are talking about the same line. Small hose from tank, over and above the starter and the trans-housing and into the scavenger pump.
Here's the part I think we are talking about....
http://www.pelicanparts.com/cgi-bin/PartsLookup/search.cgi?command=show_page&Catalog_Name=911_USA_84_86_KATALOG&Illustration=107-40&Line_Item=40
2018 GTS
Old 01-16-2008, 11:39 AM
Macht Schnell
les_garten's Avatar
Les,
Thanx, looks like the same one.
Les
Old 01-16-2008, 07:00 PM
Les,
good luck with your replacement.
2018 GTS
Old 01-16-2008, 09:13 PM
