3.2 turbo dyno chart
Someone in this town finally bought a dyno and Phil and I went up there yesterday
Phil picked up a 2005 gt3 which he ran first. It's flashed and has a full miltek exhaust. This car dyno'd at 372 rwhp at EVOMS on a mustang.
Today It ran almost the same numbers on this dynojet.
So I believe this/these numbers to be pretty close to a true number.
I'm not all that concerned with what it makes, I'm happy with it the way it is. It's been on there for 15 months now without any problems @ .6 bar. Todd says it's good for .7, but I'm not going there.
I don't know what to say about his AFR numbers. I trust my LM logs more than this wideband. I assume it's smoothed way out or something. I recorded two runs along with the dyno runs and got the same numbers I've been getting all year.
I have the raw files from winpep7 but can't open them yet.
For anyone that doesn't know, this is all bolt on stuff. Stock compression, @.6 bar
here's a chart and a LM1 screen shot of the same run
Old 01-15-2008, 12:40 AM
one of the great unwashed
patkeefe's Avatar
Jerry, that's a lot of power!
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 01-15-2008, 01:48 AM
not bad.. I am impressed.. and am going up to .6 bat on mine now
Ben
Current project 73 914-6 Gt project rusteration 2.4
914-6werkshop.com ,heat exchangers, oil tanks, etc
Old 01-15-2008, 04:13 AM
wow. l`d love to dyno mine. Are you running the stock 3.2 throttle body? that is a big restriction there and installing a bigger one should free up another 10% or so. l have mine bored out to the max diameter possible,the difference was quite dramatic.My next mod will be a diverter in the plenum under the t/body.These diverters show big improvements on the later turbos,almost unbelievable Hp gains actually if you read the dyno sheets. l think a lot of Hp can be "liberated' buy flow inprovements,the 3.2 shows it`s weaknesses there once you put the squeeze on it..
my life begins at 150MPH
Old 01-15-2008, 11:04 AM
agree 100% I think the flow is biggest obstacle at the moment.
and yes stock throttle, and afm.
Old 01-15-2008, 11:12 AM
WydRyd's Avatar
[QUOTE=jbrinkley;3705303] Todd says it's good for .7, but I'm not going there.[QUOTE]
Why not? I ran 0.7bar on mine for years before going up to Stage3. Never had any problems at 0.7bar on stock C/R Neither did Juan, Mike etc...
Anyway, nice numbers. That puts you at about 375-380 HP at the flywheel @ 0.6bar. That extra 0.1bar will take you up to near 400HP
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 01-15-2008, 02:46 PM
Cause it's scary man, lol
I might put the .7 in next time on the dyno though just to see what .1 difference does
Old 01-15-2008, 02:52 PM
WydRyd's Avatar
Expect close to 20-30Hp gain with an extra 0.1bar / 1.5psi of boost!
Don't be scared... enjoy the boost!
Merv
'89 911 Turbo Cab
Old 01-15-2008, 02:57 PM
930gt-40r's Avatar
Jbrinkley, dont worry about the dyno AFR, keep your lm1 hooked up and read from that. I have seen so many dyno AFRs read all over the place.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 01-15-2008, 10:10 PM
will do, thanks
Old 01-16-2008, 12:17 AM
