Move front brakes to rear
Hi Guys
I have a 930 Turbo and have modified the front brakes with 964 ones.
I would like to know if i can move the existing front brakes that have been taken off to the rear. Are there any modifictaions for this.
Can somebody advise
Adrian
Old 01-15-2008, 06:01 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
It's a straight bolt on, but you need to swap the right front to the left rear, etc. Also, you need to swap out the bleeder screws and crossover lines on each caliper. You can't bleed the brakes with the bleeder at the bottom!
Old 01-15-2008, 09:45 AM
cycling has-been
bkreigsr's Avatar
interesting, which rear rotors will fit this application?
Bill K
Old 01-15-2008, 10:50 AM
A fellow Pelacanite
NathanUK's Avatar
I think the stock ones are used.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 01-15-2008, 12:22 PM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
why would you want to ?they are the same size pad
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 01-15-2008, 01:12 PM
Smart quod bastardus
fredmeister's Avatar
This is dangerous stuff you are trying, because the piston sizes of the calipers Front and rear are drastically different sizes. You may now create a situation where you will lock up the rear brakes under heavy braking and spin. The caliper's piston diameters are sized to automatically bias braking pad forces and operate as a matched set front and rear, even though the pads are the same size. Once you start swapping around calipers this force balance is destroyed. Your car does not have a bias proportioning valve so this is how Porsche controls the braking force balance in the early cars.
Just be careful, and look into this more before you get into trouble and possibly wreck the car.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 01-15-2008, 01:25 PM
cool swap that`s been done a lot when putting the newer bigger calipers up front.As long as the new front calipers are bigger then the rears by the correct percentage you`ll be fine. You can add a brake bias valve to tune if needed but you`ll know if it`s close the first time you hit the track. l`d try some panic stops in a safe area while you test the system.
my life begins at 150MPH
Old 01-15-2008, 04:20 PM
Brake replacement
Ta for the info
Regards
Adrian
Old 01-15-2008, 09:14 PM
A fellow Pelacanite
NathanUK's Avatar
This has been done on my car and it does handle fine. I agree that you should test yours when you have done the swap though, that was good advice.
Old 01-16-2008, 11:10 AM
Hi
Could you advise on the topic front calipers to rear. Can i use the existing rotors on the back of the vehicle. I am a bit concerned that they are smaller than the front and that the pistons in the caliper might move to far out thus creating a leak of brake fluid.
Adrian
Old 01-17-2008, 09:57 PM
A930Rocket's Avatar
The rear rotors work fine. You can make some metal spacers to make up the difference.
Originally Posted by ady930 View Post
Hi
Adrian
Old 01-21-2008, 06:02 PM
Got Boost?
adrian
if concerned about the rotor thickness you can do as I did
use the outer peices from the front calipers and the inner peices from the rears
this way the only thing that changes is piston size
john
john bradshaw
comscc.com
porsche 930rs
SPA #227
Old 01-22-2008, 11:34 AM
