GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Les you could very well be right depending on the senerio. but typically the turbo outlet isn't as the air expands as it leaves the turbo compressor section....... boost pipe???? possibly but, on a 930 they have a generous charge tube. Unless someone has made a homegrown abortion charge tube that restricts flow. The IC inlet isn't bad but it depends on the IC, the IC core could be and then the IC outlet. I have had customer cars that had too small of an IC that was the bottle neckbwhich restricted performance. Note that the particular car I am talking about wasn't a Porsche. Also if the turbo exceeds it's CFM rating then it would be the bottle neck.
87 911 Carrera platform
Twin Garrett's, Big Valve, Xtreme Cylinder Heads, JB Racing cylinders and machine work, custom JE pistons, GT2 EVO cams, GT3 oil pump, modified 3.2L intake, 80mm TB, custom Intercooler, equal length headers, DFI, KEP Stage 2 custom twin disc, G50 custom gear set, LSD, Tilton trans pump, Fluidyne cooler
Old 01-17-2008, 08:36 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Thanks GJF and Merv, your engine looks killer GJF!!
Thanks Mate!
Old 01-17-2008, 08:38 PM
935TURBO's Avatar
And what do you thjnk about that kind of TB.....?
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 01-18-2008, 08:58 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
From the picture it looks like a quality piece. The only thing that may be a issue is the throttle cable attachment, it looks bulky and might cause some interferece with the Carrera manifold even if you cut and rotate the center section. I have had a few Ford style TB's that I had to add a recessed area in the plenum for clearence with the linkage. The other side mounts the TPS, I think that would be fine. If you can remove the throttle cable attchment piece and maybe fabricate your own arm then that would remedy that easily.
Old 01-18-2008, 09:25 AM
935TURBO's Avatar
Yes....of course, all the TBs I've fond on ebay ( for example) must be a little bit modified / adapted for the carrera manifold....but this one looks great because it is very short lenght.....isn't it...?...
Old 01-18-2008, 12:23 PM
