Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
need helps on cams and flywheel
Dear experts,
Please help out a newbie!! here is my current set up for my 930. powerflow intake, Andial intercooler, Andial fuel Enrichment, 8:39 R&P, BOV, OBX header, K27HF, 1 bar spring, BB muffler. I need advice on the cams...which cam should I go with?? SC cams, 964 cams, not sure about the Andial group B cams (AN959 1.8@overlap will that be too much??) and lighter flywheel. will they increase the acceleration?
thank you!!
Old 01-17-2008, 04:21 PM
onboost's Avatar
For a street car I hear that the light flywheel causes you to loose some bottom end torque.. although I can't verify that.
I do know that the group B cam is pretty much a top end cam.. and offers little excitement down low other than the bumpy 1100-1200 RPM idle. A lot of people seem to really like the 964 cams...
Hope that helps you some... and don't foget to post a pic of your car1
RGruppe #180
So many cars..so little time!!
Old 01-20-2008, 05:40 PM
I had the Andial gruppe B cams, as well as the Andial ring and pinion 8.39:1 Ruf lightweight flywheel B&B headers and dual out exhaust, Ruf K27/29 and it made big power down low and would pull past 6500 rpm it made 369lbs/ft of torque at the wheels. On second thought I had SC330 cams that did the trick.
Old 01-20-2008, 06:44 PM
beepbeep's Avatar
Flywheel doesn't make engine loose or gain torque. It's the engine that provides the torque. Light one won't have the same accumulated energy though so it's easier to stall when starting from a stop.
Thank you for your time,
Old 01-21-2008, 03:01 AM
obx headers
thinking about installing some obx...canyou give me some feedback about the fitment and the performance...thanx in advance ,930 chef
Old 01-21-2008, 04:35 PM
thanks guys!! I got my SC cams today!! any big difference between K27HF and K27/29?
Old 01-22-2008, 10:51 PM
sure thing!! I will keep you posted.
Old 01-22-2008, 10:52 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
