How low is low on engine oil?
I have a stock '87, I checked the oil last time on level ground, engine running and at temp. I notice I had been driven it with a few qts low I had to put almost 3 qts of oil in to bring it up to the middle of the dip stick, will that low of oil damage the engine? Where is the danger level and is there some other ways to check and fill the oil more correctly?
I use Castrol GTX 20w-50, have anyone use the Lucas oil additive is that really make the engine run smoother?
Thanks,
Yahow
Old 01-23-2008, 01:28 PM
Registered Abuser
MT930's Avatar
You should be fine. You may want to check it more frequently at the dip stick. The oil level gage on the dash works only after the car is warm and on a level service at idle. Don't use it with the the car moving. I doubt you did any damage, however you really need to monitor the oil level. That goes for over filling as well.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 01-23-2008, 04:45 PM
BoxxerSix's Avatar
Nah it'll be fine. Heck the 964's take near a full 11 qt's for a complete drain and flush, but you can start and run the engine on a little as 6 qt's without a problem at all.
Adam Hennessy
Old 01-23-2008, 04:54 PM
Thanks guys, I feel better now knowing my engine is OK.
Yahow
Old 01-23-2008, 07:20 PM
WydRyd's Avatar
If you ever do get THAT low, never run your engine under heavy loads... just take it easy until you can top it up or flush'n'fill again.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 01-24-2008, 01:26 PM
resident samsquamch
sand_man's Avatar
I've been running approximately 9 quarts in mine. See this thread for the reason why:
An interesting oil consumption observation
I run Brad Penn 20W-50. I'm a very observant owner, so I'm always under the engine lid (or under the engine itself) checking something, so I keep a close eye, but I typically keep my level at the very first (lower) line of the dipstick. My oil level gauge reads right at the top of the "red zone" mark. Just changed the oil about 600 miles ago and it hasn't used a drop...
EDIT: see my additional comments on post number 14 for clarification about the 9 quarts
-jeff
Old 01-24-2008, 01:41 PM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Ok so whats overfilling? I was told to keep it to the max line of my dipstick , how does this stick with everybody
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 01-24-2008, 02:23 PM
wcc wcc is offline
wcc's Avatar
I usually keep mine somewhere between half and low.
Bill
Old 01-24-2008, 05:22 PM
one of the great unwashed
patkeefe's Avatar
I run my SC turbo a bit low on oil, maybe a quart or so, due to drain issues. It's much happier like that. A quart low means I still have 12 quarts in the system. My experience, even pre-turbo, is overfilling = oil mess in various locations. I did notice when doing some testing on my temp sender for calibration, that hot Mobil-1 seems to expand it's cold volume by maybe 5-10%.
Good thread by sand_man, BTW
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 01-24-2008, 05:29 PM
Registered Abuser
MT930's Avatar
I keep it in between the two lines. as per the owners manual
It puts the oil gage needle in the middle as well.
MT 930
американский
Old 01-24-2008, 05:39 PM
+1 but I typically keep my level at the very first (lower) line of the dipstick. My oil level gauge reads right at the top of the "red zone" mark.
Old 01-24-2008, 06:29 PM
Porsche-Poor
bcoats's Avatar
so with oil measuring at the lower line on the dipstick, is that approx 9 qts of oil? At what level could you safely run these cars, not that I would ever get down to bare minimum but curious. I got caught in heavy stop and go traffic last summer (was 85 degrees in Seattle), oil went from upper limit on the gauge to lower limit in short order, checked the dip stick and confirmed was on lower limit, was pretty stressed out but was fine (4K on rebuilt motor as well, rebuilt K26 turbo). Now, after I changed the oil (run Kendall 20W-50), and after 1500 miles oil measuring just over half way mark on the dip stick, so interesting observation how at hot idle burning oil at a fast rate, is that a scavenger pump issue???
1979 911 RS clone hotrod
1983 930 turbo-sold, will be missed
1992 964 C2 Coupe-regrettably sold
1980 911 SC Weissach-regrettably sold
1975 911S-sold but not forgotten
Old 01-24-2008, 08:50 PM
Send a message via AIM to Chuck Jones
Glad I read this thread. I've been conscientiously putting oil in it trying to keep it slightly above the half way mark between the upper/lower marks. It seems it loses/uses/burns or whatever it does....more quickly until it hits the top of the red mark, then stabilizes there. But until I read this thread, I was Johnny on the spot and filled it again....I figure I was putting in about a half quart every couple hundred miles. I'll let it roost on the red mark and see if it slows down the consumption.
I've only got 50K on the engine...and it never smokes or belches.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 01-24-2008, 09:22 PM
resident samsquamch
sand_man's Avatar
Well, now come to think of it, when I mentioned 9 quarts, really what I should point out is that when I do an oil/filter change, I end up putting about 9 to 9.5 quarts back in...never more than 10 (and that's rare). Obviously, there is still oil in the lines, oil coolers, etc. But my goal is to keep the needle at the top of the red zone...just above the very bottom of the gauge, first mark on the dipstick. When I try to observe the half-way mark, I'll consume oil within 200 miles until I get to my engine's "G-spot" down below! And FWIW, I rarely have smoke on start-up, and no smoke on accel or decel.
-jeff
Old 01-25-2008, 05:29 AM
Large Member
krasuskyp's Avatar
Really glad I read this thread. Thanks to all for sharing their experiences here. I always like hearing "what they all do" type things about any of my cars.
Keep up the good forum work gents!
I'm going to do a search at some point as I approach my first oil change in the thing regarding brand and viscosity. I *KNOW* I'll be opening up a ginormous can 'o worms if I dare asked, both in "see the archives" and in "100000000000 different right answers" heh heh.
For now I planned on using what I used in my (22psi turbo'd) //S6 and now my Alumibeoch, Shell Rotella 5W40. I know, most know Rotella as diesel oil.
Any thoughts here before I search the archives and /or dare post up that's what I use and am seeking suggestions in a new thread? Heh heh.
Tx in advance guys! I keep saying this, great comradarie here, pleasantly surprised I wasn't sure what to expect...
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 01-25-2008, 06:49 AM
resident samsquamch
sand_man's Avatar
Knock yourself out - be sure to make a couple of sandwhiches, and pour a stiff drink...several beers will suffice:
Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
Good info here:
http://www.lnengineering.com/oil.html
I experimented with "diesel oils" in my rebuilt 930 engine; ran Rotella T 5W-40 synth and the 15W-40 dino. Also tried the Delvac equivalents. I had decent results (good warm up times and cool operating temps), although I felt that my consumption increased with the 5W-40. I did not have the oil analyzed for empirical data. However, as the above threads will show, the formulas have changed with some of these "diesel" oils, and as such, may lack sufficient levels of "ZDP" for an air/oil cooled engine. My 930 is a daily driver and I just can't justify the high cost Mobil One, RedLine, Amsoil, etc. being that I change the oil regularly.
I have had excellent results with Brad Penn 20W-50 and it's the only oil that I now run in my 930. YMMV
-jeff
Old 01-25-2008, 07:13 AM
Large Member
krasuskyp's Avatar
Senor Sand_Man...
Thanks so much for the linky's, hugely appreciated. Hmmmm... it's 12:00 "somewhere" - time for a four fingers / 2 cubes mwuahahahahaa 8-). Ah, I'll get to 'that' when I get home from der orifice.
Interesting data on the Rotella, too funny you used that exact stuff. I'll run it for the first change and note consumption. Whatever's in it now does consume a quart or so on my 40k car, so I won't have much of a barometer to compare it to.
Pardon my (perpetual) ignoramus... what's this Bradd Penn stuff of which you speak??? Never heard. Where you source?
I particularly note your selection rationale including the cost variable. Mine's an occassional commuter but not daily driver so I won't have a ton of changes fortunately. I really need to measure my drop pan and ensure she'll swallow the load heh heh. Nothing like a spitter, I say.
ANYwho... thanks again for the feedback - and not telling me to go f'n search.
Cheers...
past:
Old 01-25-2008, 07:56 AM
resident samsquamch
sand_man's Avatar
You are most welcome. Info on Brad Penn:
http://www.bradpennracing.com/
I don't know the specifics, but there is a connection to the old Kendall formula and refinery. The Penn is green in color just like Kendall used to be. FWIW, the Kendall was always a favorite of mine for my old British cars in addition to my early air-cooled VWs. I think the Penn is considered a synth/dino blend so I'm not completely certain how much it has in common with the old skool Kendall. The Penn costs me $40 for a case (12 quarts).
-jeff
Old 01-25-2008, 08:59 AM
