Need some feedback on a new gauge I am working on
Ok I have been working on this Porsche gauge for the last month and have the prototype done. here is the deal I hate aftermarket gauges and A pillar pod gauges .I have used aircraft gauges, gauges in the vents and gauges in the center console and they drive me crazy i can't stand the way they look so this is what I came up with it uses the factory computer control stalk on the steering column to control the functions and will display up to 2 wide-band sensors / Boost / air temps EGT's fuel pressure and fluid temp's it is ala cart you can pic whatever sensor modules you need ( I did not design the hardware just the format) the Screen is OLCD and screens can be customized. so give me some feedback on how it looks I will get more pic's in the AM
Old 01-25-2008, 10:11 PM
phenominal job! that is a clean install!
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 01-26-2008, 03:15 AM
Me like track days
Craig 930 RS's Avatar
Flashing AFR numbers are fairly unusable, FWTW. AFR data need to be logged to be useful.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-26-2008, 09:28 AM
Excelent!
What hardware you are using?
Can any sensor be choosen?
Which voltage scales are required?
estimated price?
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 01-26-2008, 09:31 AM
Wo ist die Rennstrecke?
DonE's Avatar
Wow Dave - way cool. I like the digital AFR - very very cool. Since you have a DTA, there's no need for logging, but what a great reference while driving. Make another - I'll buy one.
Old 01-26-2008, 09:47 AM
Registered Abuser
MT930's Avatar
Extremely Cool !
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 01-26-2008, 09:50 AM
I am mounting a USB port on the dash to allow you to plugin a laptop to datalog all sensors and yes you can choose any sensor to monitor or log
Thanks for the feedback
Old 01-26-2008, 12:51 PM
Me like track days
Niiiiiiice. Now we're talkin'!
What might be the approximate cost?
Old 01-26-2008, 02:38 PM
I had not really thought of selling theses to the public. I was going to make a few for my buddies and myself who don't like the look of an A pillar Gauge ( kind of Ricer) or did not want to get rid of the clock ( lots of good warning lights ) I am going to try one in a 930 tach this week for a local guy I will take some pics if it works let me figure out how much I have in the project and I will see what I can come up with for a price ( not trying to get rich off this deal ) give me a pm if you are really interested and we can figure out something .
Thanks Dave
C2turbo.com
Old 01-26-2008, 06:34 PM
Jeff Alton's Avatar
Can a moderator please merge the two threads??
Having the AFR appear realtime in front of you is useful, but not as good as logging it. I monitor both banks individually. It is nice to see when you make a small change to your efi program and can watch it, or have someone else watch, at certain rpm ranges. A quick glance is all it takes.
Cheers
jeff@turn3autosport.com
997 S 4.0, Boxster 2.7, Boxster S race car, 958 Cayenne TT, VW GTI 2.1 TSI, Mini Cooper S JCW, Cannondale Supersix EVO SRAM RED E-tap, Cannondale Slice SRAM RED E-tap
Old 01-26-2008, 09:15 PM
I want one!!If you consider making more please let me know, that is great work.
Old 01-26-2008, 09:22 PM
A fellow Pelacanite
NathanUK's Avatar
Jeff, how can you successfully monitor AFR on each bank as the sensors are not supposed to be very accurate if you mount them before the turbo? Maybe you have tt?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 01-27-2008, 04:11 AM
Jeff Alton's Avatar
My car is NA..... why would a sensor mounted before the turbo not be accurate?
Cheers
Old 01-27-2008, 09:42 AM
A fellow Pelacanite
NathanUK's Avatar
Due to back pressure created by the turbo obstructing gas flow.
The sensors are not accurate when under pressure, they are supposed to be mounted after the turbo.
Also, if the sensor breaks due to the heat it may damage the turbo...
Old 01-27-2008, 11:41 AM
Jeff Alton's Avatar
I can uderstand the reason about not wanting parts of it flying into the turbo, but there is no more pressure before the turbo than one might see in an NA car. Where did you read/hear about them not being accurate when "under pressure"?
Cheers
Old 01-27-2008, 02:09 PM
Jeff,
There is pressure before the turbo. That is how the turbo is powered.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 01-27-2008, 04:50 PM
Jeff Alton's Avatar
The turbo spins from flow, not pressure. Now I agree that it creates a restriction that can cause back pressure in the exhaust between the turbo and the exhaust valve. I am just curious how much pressure are we talking about here?
I thought David (125 shifter) was monitoring both banks on his efi single turbo as he seemed to know when one side was running lean.
Turbo semantics aside, I had not heard that an o2 sensor would not work in a pressurized area. Not saying it is not true, but I am curious as to why and where I can read up on the theory.
Cheers
Old 01-27-2008, 08:26 PM
78P930's Avatar
Subscribed
10 Ford Raptor
86 930
Old 01-27-2008, 09:13 PM
89turbocabmike's Avatar
Cheers
Jeff, there have been a number of technical discussions from Klaus on Innovate's website. The pressure is more of an issue with WB O2's as obviously the stock O2 sensor is pre-turbo.
Nice concept C2, looks like this is based on PLX devices hardware?
Old 01-27-2008, 09:30 PM
Thanks Mike Yes it is bases off Plx I have been working with them for the last month or so to help me get something small enough to fit in the space I had to work with in the tach.
Thanks David
Old 01-28-2008, 05:48 AM
