e p slick's Avatar
Aeromotive 65# fuel pump
Anyone ever use the 65# Aeromotive fuel pump on your 930? Results? Pros/cons? EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 01-27-2008, 03:34 PM
930gt-40r's Avatar
I got the Aeromotive A1000 on my car and love it. I dont know what the "65" is though.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 01-27-2008, 04:55 PM
How much is it? Why bother?
The Bosch 044 motorsport pump is $199 US brand spanking new and rated 200 litres per/hour @ 5 bar.
It comfortably exceeds specifications according to most tuners, flowing considerably more than most "300 litre per/hour" pumps, and performing much, much better than those when regulated to the higher pressures CIS requires.
It fits in the stock 911 front location (it's slightly longer than the stock pump) with only minor modifications (electrical connectors, hose and uprated fuse).
'77 S with '78 930 power and a few other things.
Old 01-27-2008, 05:44 PM
e p slick's Avatar
Aero pump
I have installed an ATL fuel bladder - for Silver State event - with the fuel supply now needing to be lifted from from the bottom of the tank sump. Don't know if stock front pump will do the job since it is gravity fed. Pressure check of existing pumps seems soft at 3.5 bar - I believe it should be closer to 5 bar but have not found literature with proper test pressure numbers. Thats why I am curious about the Aeromotive pumps. Besides, if I can eliminate my two existing pumps and replace them with only one Aeromotive it follows that there would be 50% lesser chance of component failure, one less potential problem. I am a strictly amateur punter, obviously, so need all the help I can get. Thanks - EPS
Old 01-28-2008, 06:32 AM
e p slick's Avatar
Is this pump - The Bosch 044 motorsport pump - used singularly or in tandem with rear pump too? If both are used what would the litres/hr and BAR be?
Thanks - EPS
Old 01-28-2008, 07:20 AM
e p slick's Avatar
Found problem
My pumps didn't pump since ATL forgot to put pick-up line and duck foot inside my new fuel cell. AN fitting on top accessed only air inside of tank. Removed fill plate for a look and found the pickup was never installed. EPS
Old 01-28-2008, 02:47 PM
A fellow Pelacanite
NathanUK's Avatar
Cool.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 01-29-2008, 11:23 AM
resident samsquamch
sand_man's Avatar
Just curious - and I'll piss-off if I'm hi-jacking - but has anyone replaced their fuel pumps just because? Or do we typically wait for something to go wrong? With a daily driver, I really try to stay ahead of things. Just wanted to get your thoughts...I can always start a new thread.
-jeff
Old 01-29-2008, 11:38 AM
A fellow Pelacanite
NathanUK's Avatar
I guess if it is not noisy then leave it alone?
Old 01-29-2008, 12:37 PM
nreed's Avatar
I have had excellent results with a Walbro GSL392 $120US - 255liters /hr. One of these replaced 2 of the old Bosch's. I do have EFI now though. Two pumps may still be needed with CIS.
Norm '86 930
DTA P8Pro ECU - Synapse BOV - 60# Siemens inj - K27HF - Dual GHL - Kokeln IC - Elgin SC330 cams -
HRE 560R 8.5x18 ET25 11x18 ET0
https://flic.kr/p/nVgoAC
Old 01-29-2008, 04:09 PM
Thanks - EPS
I'm using one in the stock location on the 'S' tub. The stock pump wasn't starving the motor for fuel, but I figured it was good insurance with an uprated K27 etc. I made 395 FWHP, and we leaned out the control pressure on the WUR.
If you use this pump in tandem with the stock rear, both maximum pressure and maximum flow capacity go up - all Bosch pumps can be used in tandem.
WydRyde has two 044's on his monster, one front and one rear.
Old 01-29-2008, 07:11 PM
Heh. The original 'S' fuel pump wasn't starving my motor for fuel (according to both measured AFR's and flow rates), but it seemed noisy (it runs when the key is turned - yes, I know), and I was suspicious of it - especially since the invoices for the last 15 years didn't include a new one that I could see, and the tub has 250,000 miles on it...
So I fitted an 044 as insurance when I bolted on all the goodies.
The brand new pump sounds exactly like the original one did. So much for that...
Old 01-29-2008, 07:16 PM
A fellow Pelacanite
NathanUK's Avatar
Mine, or at least one of them was noisy on my 930. Guess I'll leave well alone then
Old 01-30-2008, 11:22 AM
