Send a message via MSN to MKEDF
Turbo heavy Smoking....need help...
Hello..
Today i drove my turbo 911, and suddenly there was lot of smoke, i thought there was a broken ring or more....
Then i realized turbo was leaking burned oil right from the middle (started just as a drop of oil time to time)..
But today was so much smoke i had to stop the car, and forget about driving..
One funny thing i realized is that as i brought down the turbo, i noticed i could twist both sides of it with my bare hands.. is this normal?...
Im posting some pictures for you to help me find out what is wrong..
There seems to be a clamp that keeps both parts together...this one is lose..
Propeler both sides, seem firm, but exhaust side is black because of burned oil..
Should it rebuild it, get another turbo, or just adjust the clamp in the middle.. sorry about cel pics...
Any thoughts?... car was running perfect before this cloud of heavy smoke..
MKEDF, 911 78 SC (rebuilt), 75 S Turbo,2001 330CI Coupe, 2001 325I, 2001 Merc C240 V6,2003 330 I F1 (E46), 2002 320 I F1 (E46), 1999 323 I (E46),2001 Peugeot 406 Pinifarina Coupe, 2001 325 I (E46), 2000 328 I (E46), Volvo S60, Audi A4 2009, Audi A4 2008, A4 2007,2005 Boxster S, 2002 Boxster Stick Camel, 2004 Boxster S Tip (nightmare) 2003 Boxster 2.7 Tip, 2002 Boxster 2.7 Stick, Porsche 944 1983
Old 01-30-2008, 09:32 PM
beepbeep's Avatar
Tried tightening the clamp holding it together and installing it back? Does it leak internally or extternaly? How's shaft radial play?
Thank you for your time,
Old 01-31-2008, 04:52 AM
930gt-40r's Avatar
Yea, I dont think turbos are supposed to come with the "swivel option", try tightening the clamps like Goran suggests. However the oil on your exhaust wheel does not look too healthy- how old is the turbo and what kind is it (cant tell from the picture). Why is that A/N line apart in the picture, could that have been a leak?
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 01-31-2008, 05:35 AM
beepbeep's Avatar
Well if turbine housing starts dislodging itself from CHRA I bet some oil will weep past the seals and get thrown around in housing by turbine wheel, to be turned by the smoke later on.
I would remove turbine housing to check for rubbing on turbine blades. If everything is OK, put it back, tighten the clamp and make sure your (homemade?) AN line fitting doesn't leak either.
It *might* be that easy. Worst case, there is play in the bearing, rear seal is shot or turbine blades rubbed. But with little luck, everything is still OK, just greasy
Old 01-31-2008, 06:27 AM
rsrmike's Avatar
Hey MKEDF, How does the oil drain from your turbo? Does it have it's own sump w/ a scavenge pump running off the camshaft? If so you may have trouble there. I don't think the clamp would let it leak oil, if it were running fine and just started smoking like hell. If the clamp was the culprit you would probably hear some terrible noises and most likely a loss of boost as well. However, if you have scavenge or drain trouble, it would probably run ok but smoke like crazy. Of course it could always be too much oil, (we've probably all done it once) or just a bad turbo. Any history on the puffer? Just a thought, hope it helps. Judging by your profile I'm guessing this is your '75 S?
Old 01-31-2008, 03:24 PM
Non User
infraredcalvin's Avatar
I just had a similar issue with my original 3LDZ on my 76, but without the "swivel option". Mine used to smoke at startup and run fine afterwards. Every once in a while it would blow a little smoke in 4th gear full boost going uphill. Then one day on the same hill I started blowing major smoke, and boost levels dropped when should have been at full boost. The turbo seals went out. I was planning on upgrading my turbo anyway, so I replaced it. I had a little shaft play in the turbo but not much, nothing rubbing, etc. But when spinning as fast as that does, it doesn't take much. I had about a 1/2 cup of oil that poured out of the outlet housing when I removed it, so I know it was the seals.
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 01-31-2008, 07:30 PM
Issue, turbo..
You all have part reason..
I have dissasembled the turbo, 3LDZ type (original for 1977 930)...
The seals are gone, the clamp was so lose you could play with it...
The center axle is steady, the spins are on great shape, needed to install new bushings, full service to it, so we disassemble completely, and full service provided to my turbo..
Im reattaching it to the 930 engine tomorrow, and will come back here and let you know if my putt putt is back on the road again..
Thank you all..
MiCk...
PS Btw... how far is this one from a k27, what should i do to upgrade in the near future?
Old 02-01-2008, 07:19 PM
A fellow Pelacanite
NathanUK's Avatar
The K27 is a much better turbo than the 3LDZ. I bought a K27HFS to replace mine from www.imagineauto.com
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 02-02-2008, 01:18 AM
It was just like a rebuilt engine..
As i reinstalled the turbo on the 930 engine, it was started again, and it worked just like this had been just rebuilt..
AS it was smoking right before removing because of the oil leak, i had to leave the engine runing untill the oil was smoked..
This was just like rebuilding the engine and starting for the first time, i had to crank the engine to allow oil to be pumped to the turbo, this to avoid new bushings to be scratched...
Still smoking, this because of the large amount of oil dumped by the turbo on the pipes...
I guess this smoke will take a while to go away, im looking forward to ride my putt putt again tomorrow and finally get over this turbo failure...
Thank you all....
MiCk..
Old 02-02-2008, 08:45 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
