After the next project
x98boardwell's Avatar
Need Part Numbers for these oil lines?
Hello,
I have attached two pictures below and need your help. 87-930
Picture #1
1) This line travels from my oil reservoir, makes a bend up into my engine compartment and then ends up at another reservoir (not sure what this is) behind the oil fill tube. There are two lines total... what are they and what are there part numbers? Also, what is the purpose of this oil tank?
2) This is the major oil supply line from the reservoir to the motor. I need part number please? I can find this one, but figured that I would include with the request.
Picture #2
How can I stop the oil that is leaking around the sensor? Is there a gasket or something that I can buy? Part number?
Thanks for your help in advance.
Bryan
Old 02-05-2008, 03:41 PM
rsrmike's Avatar
Here is the line from question #1- That reservoir is the oil separator
http://www.pelicanparts.com/PartsLookup/HTML/911_USA_87_89_KATALOG/104-02-Frame3.htm
Here is the oil supply "S" hose-- you need 930 66/68 for turbo(the lower one)
http://www.pelicanparts.com/PartsLookup/HTML/911_USA_87_89_KATALOG/104-00-Frame3.htm
Here is the new gasket for your oil tank, you could try tightening the nuts on the one you have-the gasket is cork and it shrinks-don't get over zealous though or you may split it
http://www.pelicanparts.com/PartsLookup/HTML/911_USA_87_89_KATALOG/104-01-Frame3.htm
Old 02-06-2008, 06:13 AM
RSR Mike,
Thanks for the help. I was having trouble determining what exactly I needed from the spec sheets.
Your help is appreciated.
Bryan
Old 02-06-2008, 07:57 AM
Studs in Oil Tank Gasket?
Anyone,
When removing the bolts off the studs on the sending unit located on the oil tank, will they fall into the tank, or they attached the tank itself?
Thanks,
Bryan
Old 02-06-2008, 09:38 AM
stevie 77 930's Avatar
Bryan,
The studs won't fall off. Pressure wash the area before you start. You won't want any of that oily grime falling into the tank when you remove your sender. The new gasket is a pretty easy fix although you have to manuver the sender out of the opening.
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 02-07-2008, 09:21 AM
