fuel filter ????
Will a KL21 Mahle Fuel filter work on a 1977 930?
Old 02-02-2008, 03:03 PM
rsrmike's Avatar
nope, not if everything is original. Don't even try to remove the fittings from the KL21 these days. Last few I tried had so much threadlocker I couldn't comfortably get the thing hot enough to break it loose. Plus I don't think the fittings are big enough from the 77 to fit the KL21
Pelican should have the Bosch filter you probably need.
Old 02-02-2008, 03:44 PM
Thanks for the info..
Pelican lists a Bosch 0 450 905 281 for '76-'79 Turbo.
My car has a 0 450 905 009 do you what the dif. is?
Old 02-02-2008, 03:50 PM
rsrmike's Avatar
I think the '009 was just an older number, Bosch gets a little crazy with supercessions sometimes. If you type in the 009 in worldpac (boo!-hiss!) it crosses to the '281 or 71052-their new, improved, short number system, good luck
Old 02-02-2008, 04:03 PM
