18 inch Wheel Fitment to 79 930
Will 9x18 and 11x18 with backspacing of 6 and 7 fit on a stock 1979 930??
Old 02-12-2008, 08:53 AM
Rory Mckenna's Avatar
Can you post a picture of your 930? I wonder If I have seen it around.. I live in Centerville Ohio..
Old 02-12-2008, 04:51 PM
935TURBO's Avatar
you probably will need spacers for the rear wheels....around .5 to 1".......
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 02-13-2008, 12:42 AM
Crotchety Old Bastard
RarlyL8's Avatar
9&11 will fit, spacing may vary. What spacing do you have now, none in front and 2" rear?
Old 02-13-2008, 04:56 AM
l question the logic of this move, Porsche advises against it for structural reasons. The fact that you indicate your car is stock raises a flag also,the suspension and brakes will need a complete re-work to allow any balanced performance from the switch(according to Porsche).Having said that l have seen 18`s on early cars like yours and they can look good but it`s a cosmetic thing and not an upgrade,the extra unsprung weight will cancel out any improved roadholding. Your car is a 79? from age alone all the bushings are shot and need to be replaced and those low-pro hoops will exacerbate any suspension wear. post pics
my life begins at 150MPH
Old 02-13-2008, 09:37 AM
930gt-40r's Avatar
Im in the process of trying to get 18s, but only for the reason that I cant find 17's that are wide enough to fit real rubber on. I need to get 11 wide in the back and 9 in the front, if anyone knows about 17s in these sizes, please let me know.
Sorry for hijacking.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 02-13-2008, 02:01 PM
RarlyL8's Avatar
+1 on the 18s, there are no tires for 15s, 16s, and limitted for 17s.
You need to stay as close to 25" tall as you can. A 315/30-17 would be perfect but they don't exist.
Porsche is full of $hit with their comment on tall wheels. What's the diference between running a 25.5" tall 18 wheel with 12" wide tires or a 24.5" tall 15" wheel with 13.5" wide tires? I've done both on my SC for a decade with zero issues. Maintain your car properly and you'll be fine.
Old 02-13-2008, 07:56 PM
David's Avatar
I forget what my back spacing is, but I posted it so some searching should turn it up.
I agree that the 18's should work fine. The 930 has really beefy bearings and the 18's aren't any heavier than the 17's.
2014 Cayman S
2011 Cayenne Turbo
Old 02-13-2008, 11:47 PM
That's the reason I'm opting for the 18's. Very limited 315/35/17 availability. Although Nitto nt-01 and hoosier make tires that size. What is going to be available in 2 or 3 years? Lot's of tire choices in 18 inch land. And into the future. I am also upgrading the suspension using Elephant racing products.
Old 02-14-2008, 11:24 AM
My '78 930 runs 11s in back, on 315/35/ZR17 Pilot Sports. Not a true track tire, of course, but it will do there in a pinch, and a good street tire...
Old 02-16-2008, 09:34 PM
+1 RarlyL8.
Old 02-18-2008, 01:26 PM
Send a message via Yahoo to Lukesportsman
I've said this before (biased since I run 18's of course) but does Porsche recommend 22/31 TB's? Does Porsche recommend coil overs, huge sway bars and solid mounts? Does Porsche recommend aftermarket parts? Sure they came out to make a statement against 18's on earlier cars, but that is way before they started putting 19's and 20's on their new rides. I'm just saying that Porsche the company has different criteria for their rec's than we the enthusiast. If "P" came out and said not to run bronze bushings, would we all remove them and reinstall rubber?
It just gets old that "P" says something in a bulletin and we assume its the law. Obviously they have their reasons for saying it, but IT's not the only thing we do with these old beast that they would frown upon.
18's here 3 years and amazingly the windshield hasn't popped out of the old shell yet and that's at a bantam weight of 2325lbs.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 02-19-2008, 06:26 PM
