copbait73's Avatar
Originally Posted by Craig 930 RS View Post
Porsche has a rather odd history with regards to specifications:
1) They continually state HP on the low side
2) Weight is always under what any possible actuals could be
IE the 997 GT3 are 100-200 lbs MORE than the published weight.
A lot of GT3 owners are a bit pissed - even the GT3 RS weighs 3251
I totally agree and to reinforce what may be happening, I'm hearing Porsche started to change when the 993s came along. I've heard from several sources they think the 993 is a beautiful car BUT it's performance is piggy in comparison with the claimed weight and HP. Customer cars should perform better than they do. In particular you'll see some performance shops having a hard time getting the claimed HP on their baseline 993 engines. This makes it hard for them to sell improvements if the engine only meets claimed HP AFTER the modification.
To be fair, much of the HP loss could be from deterioration of the premium fuels we have to burn but there remains the weight issue and that is Porsche's.
Old 02-19-2008, 09:11 AM
Adrenaline Junkie
Hayabusa's Avatar
Originally Posted by RarlyL8 View Post
And the weight of gasoline on the moon is ...
Ha! Just yankin' your chain.
Hang on,,, working on that,,, hang on,,,
Old 02-19-2008, 09:49 AM
Adrenaline Junkie
Hayabusa's Avatar
Besides,,, I would never carry a curb in my 930!
You guys are whack!
Old 02-19-2008, 09:50 AM
Adrenaline Junkie
Hayabusa's Avatar
Originally Posted by DDDD View Post
Thanks Busa, I was actually going to look up the weight of gas to find out how much my gas makes a difference in the overall car's weight.
Filling up my gas tank makes a noticeable difference in how my car feels.
No prob, 4D! You know,, not that it really matters,,, because mpg in the 930 is kind of like saying,, "I have a supermodel girlfriend but don't use her!"
,,, Anyway, having half a tank or enough to make it through the day usually will suffice everything that I need and not having to be fully loaded causing excess weights and sluggishness in corners, off the line, etc. As long as you can plan out your trips to the next fill,, you can be half a tank lighter than any day with a full tank.
Then again,, leaving my portly Gfriend behind is always a good thang, too! Less nagging!
Old 02-19-2008, 10:04 AM
Me like track days
Craig 930 RS's Avatar
993 engines are pretty healthy suckers - I had one. BUt the 993 it came from......
With cams and headers (added 10 hp) it put out 280 - AT THE WHEELS ;-)
Worked well in a 2450 lb 911SC!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-19-2008, 10:14 AM
lin7310948's Avatar
78 930
last time i weighed my 930, it weighed in at 2350 with quarter tank of gasoline. car has no amenities other than basics...no radio, sound deadening, no ac, lexan except for front windshield, aluminum hood, real ruf front and rear bumpers, lightweight interior, etc. car has 425 rwhp with efi, 3.4 ruf p/cs, etc.etc and most likely for sale in the very near future..black on black!
71 911 all alum 434 sbc 585 chp 1959 austin healey bn-6 sbc zz4 motor 200r4 aod transmission......1959 Austin healey bn6 250 chev in line six cylinder, tremec 5 speed
Old 02-20-2008, 04:27 AM
Rory Mckenna's Avatar
Why would you sell it? it sounds like NIRVANA!.. it's perfect! you'll only be down grading if you sell it ahahah
Old 02-20-2008, 06:03 AM
Smart quod bastardus
fredmeister's Avatar
Would I save weight by filling my tires with helium? LOL
I know that some tire shops advertise using nitrogen instead of air to fill tires.
I bet I could save a few milli-ounces, better even because it is unsprung weight!
It is hard for me to believe that you could save 500-600 hundred or so pounds by stripping items like a/c, glass, and some insulation.
Does anyone have a listing of how much these items really weigh individually to see the direct benefit of removing items?
With this info one could make decisions on what to change out first for the greatest effect.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 02-20-2008, 07:03 AM
Old 02-20-2008, 07:05 AM
lin7310948's Avatar
why sell!
rory, i seldom drive the car and havent ever driven it very much. my everyday driver is below....585 chp all aluminum 434 sbc power weighing in at 2225 pounds!
Old 02-20-2008, 07:46 AM
PERFORMANCE THAT MAKES YOU CRY UNCLE....
Old 02-20-2008, 11:06 AM
copbait73's Avatar
I sure like your combination of light weight longhood and high HP. I'm shooting for less than 2000#
Old 02-20-2008, 11:09 AM
Here are some webpages with that info:
http://www.early911sregistry.org/jCalzia.html#Calzia%20article,%20top
http://rennlight.com/
I saved about 300+ pounds with all the basic removal items plus fiberglass bumpers. My car still has all the appearances of a luxury interior, and still has a CD player. No AC, but I get blown air through those AC vents which are still under my dashboard. I still have normal, comfortable seats.
Doing the lexan windows and fiberglass fenders and such is getting more extreme, but people do it all the time. I want my car to feel 100% vintage and normal so I don't go the final mile in weight savings.
Old 02-20-2008, 11:16 AM
930 Curb Weight
So did we ever figure out what a 930 actually weighs..
I see 3000 LBS here but all over the net and on many ferdralzation labels on 930s the weight is always stated at 3600 LBS..
Old 03-21-2018, 10:02 AM
I guess Iím asking what a non sunroof,non ac 79 930 RoW should weigh?
Old 03-21-2018, 10:29 AM
Turbo Powered Snow Blower
When I corner balanced mine it was 3,052 with 170lbs of Dumbbell weight in the drivers seat. So my 1979 930 is 2,882lbs empty.
Jim Tweet removed the sunroof from his 79 SC build and it weighed 49lbs.
And I mean actual dumbbell's, not me.
Derrick
Old 03-21-2018, 10:34 AM
Alan L's Avatar
Mine is down to 2730lb with my weight in it and 30l fuel.
Sunroof, power windows , AC etc gone.
The factory handbook with mine says curb weight 2866lb. Not sure how they managed that. Maybe flat tyres :-)
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-21-2018, 11:41 AM
IMR-Merlin's Avatar
my car with and without 165 "driver" weight, 1/2 tank of gas and no wheel, but on camber plates.
the car is fully caged, coil over car, gutted, with sunroof delete.
82 twin plugged, EFI, G50 930, RSR suspension (soon to be) GT35R...
Old 03-31-2018, 05:44 PM
full quack's Avatar
Send a message via Yahoo to full quack
Mines a EURO '84, sans sound deadening, all a/c stuff, no rear seat fold down backs or rear seat belts, no spare, no tool kit, fiberglass rear bumper, no front skid pan, Fikse wheels, no auto heat (back dated to levers), RS door panels, hollow torsion bars, plastic air filter housing, no smog equip. of any kind, B&B muffler, minus whatever I can't remember.
2700 lbs. dead even, with 1/2 tank of gas, as measured on highway scales and when corner balanced.
Mark
Old 03-31-2018, 07:26 PM
Did you read my reply?
Originally Posted by slow&rusty View Post
Please look at the Digital Radout on the Building. This is a Department of Transportation approved and callibrated scale.
My car is an '89 with 1/2 tank of gas, full A\C, full interior etc etc...on other words nothing removed.
Yasin
Old 04-01-2018, 05:17 AM
