dp951's Avatar
91 turbo motor ijn 1985 car ??
My question has any one installed a 91 turbo engine in a 85 turbo car, useing the wire harness and dist from the early car? I know they turn in different directions (oppisite)..is there a kit or dist modification?
Old 02-08-2008, 11:55 AM
E-85 sippin drunk
turbobrat930's Avatar
Hmm, I may be mistaken...and if I am... I will be reprimanded...... BUT, A 91 is basically the same motor, FI system and everything else that an earlier car has... (turbo that is). I think you may be thinking of a N/A 91...which has the 3.6L, Then you would be correct about the dist....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 02-08-2008, 06:45 PM
vmb vmb is offline
vmb's Avatar
This is worth a grain of salt, but I bought my '79 w/ a '91 turbo motor already installed. Unfortunately, I know nothing about the actual transplant. But it can be done!
Vic
'79 930
'97 Miata M edition
missing my Tony//Kart 125cc shifterkart
Old 02-08-2008, 07:42 PM
beepbeep's Avatar
Same engine, IC is little different (which shouldn't bungle up the install). So my guess it's plug & play.
Thank you for your time,
Old 02-09-2008, 02:52 AM
vmb vmb is offline
vmb's Avatar
my 91 motor is actually using the 79 IC, I guess that supports even more compatibility. (Ruf IC in a box waiting to be installed, among a dozen other upgrades)
Vic
Old 02-09-2008, 05:56 AM
Forced Induction Junkie
WERK I's Avatar
Didn't the 91 C2 turbo's have power steering driven off the passenger side camshaft? If so, there are adapters out there that take care of that issue. The '91 3.3 turbo engines are identical to their predecessor's except for the fully finned cylinders. The IC is different as mentioned earlier. I agree they may have used a K-27 7200 or 7006 as a turbocharger.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-09-2008, 08:22 AM
930gt-40r's Avatar
I think you have to lob off the end of the cam in order to fit the little o-ringed cover back on and use the engine oil cooler (unless you just want to use the filter instead). The case is actually diffrent (a little bit) from the origonal 930 motor but nothing that effects install. Why couldnt you just use the stock C2turbo distributer with an msd box? That engine would not be hard to intsall in a 930, the only other thing I could think of is having to re-pin the wire harness main plug
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 02-09-2008, 05:41 PM
A fellow Pelacanite
NathanUK's Avatar
I thought the C2T had electronic ignition timing control. EZ69.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 02-10-2008, 12:58 PM
930gt-40r's Avatar
maybe it does, if thats the case run to whole harness and control unit
Kris @ Tech9
86' 930/GT-40R Sold
Old 02-10-2008, 02:22 PM
dp951's Avatar
91 c2 turbo install
Thanks guys , yes the 91 has computer controlled advance and the harness is different, does any one know where I could find swap info, harness info ect ? Thanks
Old 02-17-2008, 06:03 PM
