71 911 turbo strap on?
Im rebuilding my 911s. My numbers dont match so Id thought Id tweek her a bit if possible or I may just restore.
Im pretty sure b/c of the high compression of my 2.2 that turbos are out b/c it would blow the engine in short order. True?
recommend?
thoughts?
free pizza?
Old 02-21-2008, 06:53 AM
Macht Schnell
les_garten's Avatar
recommend?
thoughts?
free pizza?
Hi,
A little off your topic here, but if I had a 911s with some triple draft carbies on it, there's no way I would mess with the beauty of it with a Turbo. I might try to increase displacement, clean it up, plumb in some SS lines, refurb the interior, etc. Personally, I just think there is beauty in those old engines!
Just my .02
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 02-21-2008, 07:02 AM
Originally Posted by les_garten View Post
Hi,
Just my .02
off topic? not at all. I appreciate this. I have pained about this. If the numbers matched I wouldnt even consider it. But boy it would be fun.
I think its not even possible. I mean its possible but the compression would make it like a race car. Good for one day or two and then time to rebuild. Dont think I want that but I thought id get some feedback from the powers that be.
Shes quite fast as she was. I mean tired old engine use to just scream at about 3400. It was unnerving. then one night at 11pm around 60mph. Oil pressure - 0, oil sump 0. aaahhhh turned it off immediatley and coasted to a gas station. too late. : ((( she was gone. I tried turning the crank with a big ass ratchet. Wouldnt budge a bit. bummer.
71 911s
Old 02-21-2008, 07:15 AM
copbait73's Avatar
You should rebuild with a replacement block but to S specs.
Are you sure it is an "S" engine. Many were removed from street cars to go racing.
Old 02-21-2008, 07:57 AM
Ironically thats what was done here. Its a T body but an S engine was installed in it which is why the numbers dont match.
71 911s
Old 02-21-2008, 08:55 AM
copbait73's Avatar
Does it still have MFI?
Old 02-21-2008, 09:03 AM
yep
71 911s
Old 02-21-2008, 09:22 AM
copbait73's Avatar
Save your long hood T, sell the "S" motor to someone restoring an "S" car.
Buy a 3.2L to drop in your car - pass on all the offers for 3.0L SCs. Go stock or add Wong chip and SSI. You'll have lots more HP and torque. The 3.2L will make you instantly forget you ever had a small displacement "S" motor.
Old 02-21-2008, 09:33 AM
e p slick's Avatar
Faagetaboudit
Faagetaboudit. No benefit to your turbo thoughts - plans. Fix the T and enjoy it for what it is. Consider the horror of having a transvestite freak of a car...
If you want a Turbo buy a Turbo. EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 02-21-2008, 10:45 AM
Thanks for the tech slick...
I dunno I may still do it. Ill look at some turbo kits. Its a play car anyway.
71 911s
Old 02-21-2008, 10:54 AM
Macht Schnell
les_garten's Avatar
How much Bar ya runnin' on that Sled!
Les
Old 02-21-2008, 10:55 AM
e p slick's Avatar
Bar
Actually there is a Boxster under this deceptive and stylish shell.
So in this case BAR would stand for Boxsters Are Ridiculous
I am having it upholstered in Nogales this weekend.
Dingleballs will be added next week.
EPS
Old 02-21-2008, 02:25 PM
Me like track days
Craig 930 RS's Avatar
Do a Google search for 'Strap On' ;-)
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-21-2008, 02:41 PM
Craig is funny!
Old 02-21-2008, 03:12 PM
e p slick's Avatar
Strap-on
Cause he's got a strap-on?
Old 02-21-2008, 03:46 PM
I hope he doesn't need one...
Old 02-21-2008, 04:33 PM
Well he shouldn't. He's got one darn nice 930!
Old 02-21-2008, 04:34 PM
rsrmike's Avatar
You could always send your engine to Motor Scheister for a low-compression rebuild, complete with the strap on treatment. It doesn't sound like they use any lube though...
Old 02-21-2008, 04:49 PM
Macht Schnell
les_garten's Avatar
Last time I was on a thread like this, the Puritans, The Pilgrims, and the Girl Scouts showed up and were shocked at all of us!!
Les
Old 02-21-2008, 06:31 PM
A fellow Pelacanite
NathanUK's Avatar
LOL
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 02-22-2008, 02:32 PM
