Can I use axels from 85-89 Turbo
Hi
Can someone tell if I can use axels w/cv joint from 85-89 Turbo in a 930 1979 model with G50 gearbox from Patrick Motorsport.
I just broke an axle and this was in the car when I bought it – so I do not know if I am using std 930 axels.
Want to use if possible:
GKN Motor Sport Axle Shaft Assembly
For 911 Turbo 85 thru 89 Item #: 93033203704GKN
.Premium bar material is gun drilled, honed, and 26% stronger. Premium finned GKN Motorsports joints with improved cages and cryogenically treated housings are 16% stronger.
Old 02-21-2008, 03:54 PM
lite75's Avatar
Should work, I'm using a g50 with 89 turbo axles in a 75 930.
75 930, 76 930, 83 SC EFI turbo
Old 02-21-2008, 06:04 PM
I think tne part numbers are different. Changed in the mid 80s? Not sure if it is a different spec.
Old 02-21-2008, 06:10 PM
930gt-40r's Avatar
I believe that porsche changed the cv joints at some point, but not the bolt pattern
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 02-21-2008, 08:52 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
